GDS 3 KW generator runs on water
Started by ramset, October 25, 2014, 09:24:26 PM
MarkE
Critical review has yet to delay or prevent any working energy device from reaching the market.
Nink
ramset
Mark E
am I to assume this thread represents your opinion of Critical review?
@NInk
I am sorry to read your contributions here represent your quality of scientific rigor.
Job applications and cut and paste investigations .
Did you just Pile on and not read the thread? did you not read the part where we have an opportunity /invitation
to perform scientific measurements of this device?? If so please explain how ANY of your contributions to this thread are of any value other than to Inflame an already volatile and at best tenuous  situation?
Nink, have you ever in your life performed or contributed to such a test
in any way whatsoever??
thx
Chet
Thanks Grandma
ariovaldo
My new toy.....
This weekend if I have time, I'll connect the water pump and see the input and output in a simple way...
To say the truth, I expect not more than what we can find in the engineering books....
mscoffman
Quote from: ariovaldo on November 06, 2014, 03:00:56 PM
My new toy.....
In my opinion the pelton wheel pump does not have good evidence for him using it. The main reason is that the water level
in the tank is not constant, so the pelton wheel generator would have vast changes in environment as the water level changes.
So it may only be there for stirring water around for cooling. Someone pointed out that the pelton wheel is too small to run
all the power through, which I think I would agree with. For example someone pointed out that the dump load controller
has not had its relay wired. The pelton wheel with a PMA alternator would require the load dump resistor circuit for regulation.
Also someone else pointed out that the pelton wheel was not running when the video demo is going on.
In my opinion what would work is if the high pressure pump is using overpressure to run the larger sump style low pressure
pump by causing it to overrun its RPM. The low pressure pump would have a constant environment as the water level would not
be changing and if the rotor is overrun the AC motor would be begin operating as a synchronous alternator with enough capacity
to circulate the whole power capacity through. An DC-AC inverter would be reserved for use as an VR and exciter for the pump
motor used as the synchronous alternator.
The control knob with arrows drawn on it is probably and oven PWM thermal controller that uses a manual input
and a local resistor element to set the PWM pulse width modulation low frequency to drive the DC input motor.
It would work like the old automobile thermal blinker unit but with manual frequency control.
Well the above I believe would bring operational capability to the unit except that a battery charger would probably be required
to recharge the lightly wired battery.
He's going to have to bring overunity to the table but scroll pumps and chaotic water situation have both been used as people
having seen overunity situations associated with them.
:S:MarkSCoffman
