Tesla's rotating magnetic field generator
Started by giantkiller, September 13, 2006, 06:19:55 PM
giantkiller
Snap, crackle, pop...
The basic Patent is Tesla's 390,721. The patent exists for the mechanical. The full implications are not fully documented.
Step 1: a 4 coil toroid that generates a rotational magnetic field.
a frequency above 40k hz generates free power across another coil.
Proof: Tom Bearden stated that a spinning magent operates exactly like a gyroscope. The same laws of physics apply.
Proof: Steven Mark demo'd the effect with his 3", 6" 17" coil. 5k hz is too low.
Step 2: A duplicate 4 coil toriod mechanically meshed with the first one, operated in reverse order.
The easiest way to get the mesh is to use dual conductor or speaker wire.
Proof: Steven Marks has 2 on switches on the 17" coil. Counter rotating magnetic fields produced by 2 intermeshed 4 coils rings.
Now when both rotation speeds are the same the effect is one crossover point some where on the coil. This obviously can be used as an x/y navigation during Levitation.
By varying either speed ever so slightly precise shifting control can be gained.
So how do we achieve higher interference rates? 2 ways: increase the current to the coils (this creates more flux lines) or up the rotation speed  (This causes more lines of fluxes to cross each each other). Or, oh my God, do both!
Now we know that any rotational speed higher than 40k will radiate magnetic fields, like radio, microwave.
By putting the higher speed emminations in a toroid we end up with a magnetic compression engine. The center is a twisted, highly compressed magnetic force that produces a magnetic black hole.
In the compression center as the lines of flux are highly enregized and cut through each other both but can't cross center, the toriod ( with a twisted center) becomes a
magnetic ball that at different speed causes really fantastic anomolies. Would you care to speculate, like levtation, cloaking, interdimensional traversing of space.
We are talking huge field effects. These effects are already shown at the shoutwire site for the SETI alien contact video.
My avatar is the next coil rendition. And how do I get the high current into it. I will wire one coil to the 1,2,3,4 spark wires of an autombile and run the 1,2,3,4 of the other coil to
another vehicle to run at a different speed. The RPMs won't get above 40k on the ring rotation speed but the interference speed should be high enough. The only problem is you show up on radar.
So be cool.
On another note:
The hutchison effect is the application of a 2nd frequency against the base frequency of our magnetic environment and another frequency imposed against that. The effects are caused by the line of flux cutting across each other. Anything in the way gets altered, weight, atomic makeup.
The Lifter technology proves levitation. The instability is from being on the edge of the field. It wil never be stable because it is on the end of the field.
I made a previous statement to the release of information to the world as I get it. I am up all 24/7 in spells analysizing and deriving. Anybody out there taht doesn't want to believe or understand then that is your problem. None of the findings here break the laws of physics. Stay on board. See the SETI contac video!
I don't want to sell this because I don't want visitors. And nobody can sell this. This knowledge is now public domain and the government doesn't want that.
Once again, cut the crap theories. The force, Luke, is called the magnetic field between the lines of flux, not aether. Start your on new age post and stay out of reality.
The gauntlet is thrown.
I slay giants, lest I die in darkness.
Oh, and by the way.... You heard it first! Now tell your friends and pass it on and lets get this show on the road.
kames
Hello giantkiller,
Hmmm?, interesting. The uniqueness of Tesla rotating field is that the coils (magnetic poles) are placed along the perimeter of the toroid and not towards the center of the toroid, like in most of the electric motors. Despite that, a compass needle is still rotating even when placed in the center of the toroid, which is based on the theory should not have any magnetic flux getting outside the magnetic core. Did you see, I believe SciFi or History channel, a movie about Tesla museum with a rotating compass needle? There are some reports and patents, even very recent, that the net energy gain is obtained by moving around the magnetic flux in opposed to crossing it. Not sure if this is the case for Steven Mark, he is using a permanent magnet, but who knows.
Not a problem for me to use 40 kHz, however, using two rotating fields in different directions is also worth of testing.
Not bad at all. If you have any anomalies recorded, can you tell us about it?
Regards,
Kames.
Jdo300
Hi Giantkiller,
You and I are both on the same page with the Mark Device there! I too have been doing some extensive research into the Tesla rotating magnetic fields, although the rendition I ended up with finally was not in the same form as Tesla's device. I attached a picture of what I made at the end of the post. Basically, it is a toroidal transformer with two large coils wrapped around it at 90 degrees. The idea was to feed current into the two coils 90 degrees out of phase (like a two-phase motor) to create the artificial rotating field. Then I could induce current in the toroid. Right now, I set it up to work at 5kHz which puts out little to no power so I'll need to change my caps and up the frequency to something higher (like the 80 kHz that you mentioned).
But I wanted to ask you, how are you going to feed the power into the four coils to create the rotating field?? I want to try that experiment for myself as well to see what I can get. Are you using an air core for that test or a ferrous core?
God Bless,
Jason O
giantkiller
Dude, that is shaweet! Where'd ya get the core.
I have Iron pipe core now. Tao told me about styrofoam toroids at Craft stores. I can wrap another one up and throw it into the design. My platform is totally programmable.
I started posts in the 'Master of magnetics' section. Simply because that is where everybody is. This thread is not achievable unit the SM coils are reversed engineered.
I am putting doco together now. For power I am either gonna use PVC or copper pipe with ten turns of 16g wire connected directly to the avatar configuration. I then slip these coils pickups onto spark plug  wires 1,2,3,4 on my truck. Ain't that redneck?. Variable speed?!?! at great voltages.
We be rockin' to a meltdown!
And "God bless" to you too, brother.
As you can see by my avatar the configuration has grown. "It's alive!?!?!" I am now investigatng driver circuits. There is a ton out there.
It is not what we do now, but afterwards that make us great!
Fire back when you can...
Ciao.
Jdo300
Hey Giantkiller,
Actually, I made the core in the picture myself from some scrap 1" thick Lexan I found (I have access to the machine shop at my school). Good luck with the spark plug idea, not bad at all though I'd watch out for the HV spikes you'll undoubtedly make. As for myself, I have a couple of function generators that I can use to produce the two frequencies in the coils. I have some additional thoughts about this that I will post later as I a do experiments. My first goal for now is to wind the coils for the collectors and control wires. At the moment, I'm trying to decide what gauge wire to use for the control wires. I'm leaning toward using my 24 gauge wire for the collectors. Steven talks about using multi-stranded wire for them so I can cut a few lengths of the 24 gauge and wind them through my tubes (see my other post on the Master of Magnets thread for more info).
God Bless,
Jason O
