The new generator no effect counter B. EMF part 2 ( Selfrunning )
Started by syairchairun, November 09, 2014, 09:05:00 AM
After you look at these images you have to forget them.  You also have to wipe all cache and other files on your computer hard drive by writing all zeros onto the dangerous disk clusters.  Failure to do this will result in a visit from the CPW.  That's "city public works" but you have to forget that I told you that.
lumen
Luc,
Nice core!
I think you are getting ahead of me. It looks like things are fitting together well for you.
I think you could just wrap some thin fiberglass tape or some plastic around the core to wind the coil on so it doesn't cut the wires coating.
It would be nice to keep the gaps close as possible between the rotating C and the core sections. That's the point where the flux is contained in the core.
I ordered some silicon steel sheets that I will mill up into the second design but it looks like the holidays might slow me down somewhat.
You do know that this is all theory and is the only theory I can imagine that would allow the generator from Syair to operate as shown.
Is this like Jim Murray's patent?
gotoluc
Thanks for the reply lumen
The cores are from a microwave transformer I cut open.
Yes, I do know this is all experimental and no guaranty of anything working :o
I was definitely going to wrap the core with heavy tape before winding. However, before I do, what do you think of the idea of cutting in a little so the coil sets in the core?... would that help direct PM flux towards the C core or would it do the opposite?
Thanks
Luc
dieter
Would you mind if I join this discussion?
I think it doesn't make a big diffrence, probably reduces the flux as it is a further curve and as it reduces the cores diameter. Remember how big the inner core of a MOT is.
What saw did you use to cut it?
Peace
MarkE
Quote from: MileHigh on December 23, 2014, 10:14:06 PM
At low frequencies fluid and mechanical analogies to electricity work very well.  At high frequencies the analogies can become problematic.
Beware the CPW men in black coveralls.  Those coveralls were once white.
