0 Members and 32 Guests are viewing this topic.
lumen
Quote from: Just..Sayin.. on December 01, 2014, 01:12:38 AM
I think you are right. People need to see the original video, the demonstrations without the motor driving the generator are very impressive... very! Producing the wattage by hand that is needed to run the three power tools is quite a feat. The power is clearly coming from the generator at that point in time.
Here is the original 37 minute video Syair edited for some reason or another, down to 25 minutes.
I also am wondering if the belt movement and sound change when welding is a result of the motor no longer having the current and voltage available to power it because of the drain on the generator from the welder.....or perhaps... is there a substantial amount of hysteresis being developed with the very high amperage draw?
https://www.youtube.com/watch?v=3DKUFoWAuj0&list=UUaKHAdY13gp-un2hn_HJehg
The original video was very impressive, that's why Syair should be showing the design for that generator instead of another design.
I for one would like to know the design of the same generator shown in the video and not some other plan that might work something like it.
If you had a generator that worked that well, why would you waste time trying to build a larger one?
With a few batteries it would be enough to run your entire house as is.
thngr
this idea of the generator is the greatest one of all times! there are two great powers while producing electricity by generators today one of them elektromagnet the other is generating coil that induces so much worse back EMF. force both of them duel with each other " iron wall is messenger" nothing to do with the fight!(this knowlage seems like divine rule.)
if one do not understand how it works then he must do as it said. But if you understand how, so simpler vertion is:
thngr
Quote from: thngr on December 01, 2014, 11:42:20 AM
all iron laminations are isolated silicon steel but not necessary for the stationary magnets.
For Syairchairun design rator holders(inner disks that holding iron wall between magnets and coils) are non magnetic material like duraluminium as hard as it can be.
Kator01
Hello,
I know you may not like this but it is not uncommon to have this kind of output by turning a pm-generator
by hand-power. So this alone is no proof.
See this generator-demo of a standard pm-generator produced by a polish company
https://www.youtube.com/watch?v=7EVDhLQ17uk&list=UU7cu67V16UL5LfelkIyNPCA
regards
Kator01
thngr
http://www.overunity.com/15083/the-new-generator-no-effect-counter-b-emf-part-2-selfrunning/dlattach/attach/144719/
in this attachment[/font][/size] four Shaded-pole stator can be found 100-200W fan motors, But some motors came with oil or oil free bearings can couse 100-200w friction on bearings! use ballbearings insted. you must cut also Shaded-pole short circuit coils. you can not use rator of the motor because of short circuited squirrel cage on it.
