thngr
Quote from: Kator01 on December 01, 2014, 12:25:10 PM
Hello,
I know you may not like this but it is not uncommon to have this kind of output by turning a pm-generator
by hand-power. So this alone is no proof.
See this generator-demo of a standard pm-generator produced by a polish company
https://www.youtube.com/watch?v=7EVDhLQ17uk&list=UU7cu67V16UL5LfelkIyNPCA
regards
Kator01
I gues you did see a lot of scam! But why are you here to read somehow. Try to analyse step by step.
what is happing ordanary generator and what is happening on this topic. there aren't all users read here because of same reason!
Just..Sayin..
Quote from: lumen on December 01, 2014, 10:47:54 AM
The original video was very impressive, that's why Syair should be showing the design for that generator instead of another design.
I for one would like to know the design of the same generator shown in the video and not some other plan that might work something like it.
If you had a generator that worked that well, why would you waste time trying to build a larger one?
With a few batteries it would be enough to run your entire house as is.
I too would like to see the original design. I believe it is much superior. You cannot beat the minimal rpm that is required. The cogging is very minimal for all the power that is being produced, and should not bother anyone... it is no big deal.
As for working on a different model it is very easy to understand why he is doing it, it is partly tunnel vision, and partly ego, we are all guilty of it at the best of times and we can never seem to leave 'well enough' alone.....
thngr
Quote from: Just..Sayin.. on December 01, 2014, 01:12:38 AM
I think you are right. People need to see the original video, the demonstrations without the motor driving the generator are very impressive... very! Producing the wattage by hand that is needed to run the three power tools is quite a feat. The power is clearly coming from the generator at that point in time.
Here is the original 37 minute video Syair edited for some reason or another, down to 25 minutes.
I also am wondering if the belt movement and sound change when welding is a result of the motor no longer having the current and voltage available to power it because of the drain on the generator from the welder.....or perhaps... is there a substantial amount of hysteresis being developed with the very high amperage draw?
kapanadze genarator can not weld, I think!
T-1000
Quote from: thngr on December 01, 2014, 11:42:20 AM
this idea of the generator is the greatest one of all times! there are two great powers while producing electricity by generators today one of them elektromagnet the other is generating coil that induces so much worse back EMF. force both of them duel with each other " iron wall is messenger" nothing to do with the fight!(this knowlage seems like divine rule.)
if one do not understand how it works then he must do as it said. But if you understand how, so simpler vertion is:
How about this? :)
http://www.overunityresearch.com/index.php?topic=2678.msg43489#msg43489
Dog-One
So do we have any more news about this "RamaGen"?  From the source?
I'd like to think these two videos were not just teasers.
