Pulse motor build off time.
Started by tinman, November 15, 2014, 01:18:57 AM
Quote from: TommeyLeeReed on November 21, 2014, 07:10:08 PM
Hi All,
Ok, just about finished on this pulse motor build off.
https://www.youtube.com/watch?v=Lyokf2F63kI
Tom
Beautiful work, Tommy!
Like Chet, I also used to work on big aircraft radial engines. They are amazing, especially the master-rod system, same as you have shown. Even more amazing are the valve-actuating cams on the big ICE radials: they are huge rings, with cam lobes along the outside and gear teeth all around the inside.  It's a good thing you don't need those in your setup!
Can you imagine the crankshaft-master rod system of 28-cylinder engine, 4 layers of 7 pistons each?
http://en.wikipedia.org/wiki/File:Biggest_rotary_cutaway.jpg
TK:
I love those real-life cutaways.  I but you they don't make them that much anymore and some of them must be collector's items.  Cutaway drawings are great too.  They always appealed to nerd in me, from being a kid right up to the present.  Cutaway drawings of things like submarines and ocean liners were pure brain candy for an inquisitive mind.
Chet:
Looking forward to the update.
synchro1
@TommyLeeReed,
Take a look at Art Porter's "Magnetic Neutralization" project. An axial disk magnet for piston, sandwiched between two opposing disks on top and bottom with two neutralization coils would add power and efficiency! This approach eliminates "Lenz Drag" because the BEMF output is augmented  by a Dragone effect.
http://www.gap-power.com/index.html
tinman
Hi All,
Tom
Looking good so far Tom.
Cant wait to see it run.
I have gone to plan B,as plan A got shot to hell once i found out what the stator core looked like under all that plastic :'(
TommeyLeeReed
Thanks all,
TinMan, just pick a idea of a type of build and work around that.
You will do great....
I like the idea of building everything to this PMBO, I think it would speak louder then finding a motor and doing tricks with it.
Tom 8)
