Lenz free generator
                    deep breath in,holding :"I am pulsing."
                    thinking ::)
                    deep breath out : Aha ;)
                    Very interesting...
                    Compare auto-transformer and "your: I am ...... "  Wake up,child (Kate Bush)
        Wheatering High
tinman
Quote from: webby1 on October 04, 2016, 09:07:47 AM
Misc. rambling,,
When dealing with coils, with and without cores, I still vacillate over if the collapsing field from a pulse is collapsing back into or away from the coil and or core.
Is it the same for an air core and a permeable core?
Is it the local environment rushing back in and replacing or is it the local environment pushing the "bubble" back to where it came from.
To use a coil,, well the way we use them I don't think it matters but if we wish to use them differently it might matter a lot.
Drop a pebble into a pond of water--you now have your answer.
Brad
Magluvin
Quote from: tinman on October 04, 2016, 06:55:08 PM
Brad
Grass Hopper   ;D
Mags
web000x
Quote from: Erfinder on October 05, 2016, 03:11:28 AM
"Reduced Impedance Effect".  A condition which can be established in inductors, a condition suggested by Paul Babcock.
Who has heard about this?  Of those who have heard about it, how many believe it's real, of those who believe it's real, how many believe it can be demonstrated?
I have heard of this and halfway attempted to replicate it at one point.  I am not sure I saw anything interesting as I was not doing it exactly like paul does with the controlled collapse of the inductor thru his switching process.  But I would think the same thing should happen in pulsed coils where the inductive reactive energy is collected in a cap or used up somehow.  So theoretically if all of the magnetism has been removed from the coil, the coil should show a reduced impedance to the flow of current and all pulsing/capturing rigs should exhibit this reduced impedance phenomena.  I don't think they do... What are your thoughts on where the disconnect is?  Since Paul talks about being able to run full current thru 300 mH coils at 400Hz....
Dave
tinman
Quote from: webby1 on October 05, 2016, 06:46:58 AM
Do you think that is the full answer?
If you remember that that "pond" is a 3D sphere and not the flat surface you see.
Personally I do not think the pebble and pond is the answer.  I think it only represents a mode of propagation.
Your question
Quote: When dealing with coils, with and without cores, I still vacillate over if the collapsing field from a pulse is collapsing back into or away from the coil and or core.
We live in the field of a magnetic pond,and pulsing a coil dose to that magnetic pond,like the pebble dose to the liquid pond.
