The 'free energy' spark
Started by pomodoro, January 06, 2015, 02:30:01 PM
jbignes5
Quote from: Zeitmaschine on November 19, 2016, 06:30:16 PM
No more to say about my preceding statements?
The correct answer should be, clotted/solidified aether, I'm made of.
jbignes5, where can I see a tower acting like a capacitor pulling down plasma from the ionosphere in a Kapanadze video?
But here I can see three more concentric »magic« capacitors in action. Since the sparks of the (eye-candy) Tesla coils can hit those capacitors safely, each of them must have a ground connection. Further more, each of the three yellow output wires is connected directly to one of those capacitors. Conclusion?
Kapanadze Was reproducing Tesla's other methods and devices. The tin can was not anything but an oil filled transformer. That special one from the Speech.
jbignes5
Does this look familiar?
5. is the best example of the Turkey showing. It's only a partial reveal of the proper system.
Let me ask you this? What are sparks and arcs? Plasma is all around us. Discharges are proof of that. But Tesla knew that he was condensing plasma in his earlier systems. What he needed to do was condense this plasma around the free terminal of his oscillator increasing the plasma density and magnifying all energy transfers in the process. Also if you could keep the plasma condensed it would allow more plasma to gather and eventually allow a better flow of plasma into the ground where it wants to be. Plasma doesn't like to be displaced and that is what matter does. Plasma flows into our globe and it's origin is from our Sun. Why shouldn't we be able to condense or pressurize plasma and allow it to go to where it wants to be (ground). Why shouldn't we be able to harness that flow?
These other explorations of Tesla's work was to prove he was going in a direction and where that was leading him. Each experiment was a step to the ultimate understanding Tesla figured out about our world. Each phase was directed twords an aspect of understanding what induction is and how to harness it for our use.
Zeitmaschine
Yes, jbignes5, something looks familiar, but in a rather concentric way.
Here more candidates for our collection »free energy by concentric (magic) capacitors«.
Candidate one: Searl Effect Generator - Wikipedia, the censored encyclopedia, (deleted due to ignorance)
Searl Effect Full Disclosure, it works with concentric rings and ionized air? Sounds also familiar.
Btw, also censored on wikipedia: Testatika
Since these censored pages are still retrievable on archive.org, surely it won't hurt anyone if they were also still available on wikipedia.org, will it?
Candidate two: The Hubbard Coil. The statement »extract power from radium« is pure nonsense. Because »extracting electrical energy directly from the air« was hard to believe by some, he had to make something up more »plausible«. Since the Hubbard coil/transformer obviously runs on high voltage (step-up transformer), there is clearly more going on than just generating magnetic fields by means of a couple of coils.
But what about the Moray Device? Unfortunately we can't see what's inside the Moray device - or can we? If the image below is authentic, then it shows Moray's 100W device. Here again we have two cylinders looking like wire wrapped round metallic tubes, resulting in two concentric capacitors - and an additional coil on the right-hand side - fitting surprisingly Harold Aspden's figure 7. All coincidence, or could that Moray device be the candidate number three?
Anyhow, it is evident that each device that taps the aether energy makes use of concentric capacitor arrangements. Amazing.
Magluvin
Quote from: jbignes5 on November 14, 2016, 08:35:09 AM
Yeah capacitance has a bunch to do with this. Shuttling the charge back and forth between the plates and inducing a Pulsed DC component from that process via bifilar coils.
The figure one from the Colorado notes could also have a bifilar primary to reduce the bemf effect to the source.
The capacitance in his tower was on the above ground terminal to the ground terminal. One plate always being 0 and the other due to elevated potentials being 100v per meter high.
When the one plate gets enough potential gathered a bulb of plasma should be attracted to it and increase the umph when shorted to ground via the spark gap to ground through the coils.
The place to pick off extra energy is the self shorted coil and cap or even a self terminated bifilar choke as shown in his technical writings Pulling charge from that would be simply opening that bifilar choke and draining the energy from the increased capacitance of the bifilar in a pulsed method.
The tower is simply a capacitor just like our planet has a capacitor in it's design. One plate being the ionosphere and the other being the earth. The coils between the cap must extend the one plate (top plate) virtually higher up and this pulls the plasma down from the atmosphere. Once you get the plasma down to the plate you can funnel it through the coils and into the ground where it wants to be. To the plasma the ground is a vacuum. This is due to matter displacing the plasma field in the earth.
Time it right and it should act like this kind of sprinkler:
https://images.duckduckgo.com/iu/?u=http%3A%2F%2Fecx.images-amazon.com%2Fimages%2FI%2F51KVelwmxfL.jpg&f=1
As for TK devices, well he was only verifying the Tesla process, this usually involved a ground connection and a way to stimulate the process to start.
Just a simple question for you guys. How is it we can draw energy from a battery or capacitor from the + and negative but we can't seem to draw energy from the positive and negative of the Sun replenishing earth capacitor? We can and we could have essentially free energy to power our civilization. The one problem is the powers that be. They don't want us to be equal. Money is the great divider of people and the great suppressor of the very thing that can free us. It's all there. We just need the courage to go and reap the harvest waiting for us.
We know one thing now that this earth and the effects we see from this capacitor's discharges drive the weather we see today. This means that if we could siphon off some energy flowing towords the ground that we could change the weather to a more pleasant level. We are now sure that the Sun and it's solar wind are driving this mechanism. If we tapped that mechanism and take off energy then what effect would you think would be the result? Take energy out of the system would do what? Lessen the strength of the effects of that system right?
Below is the explanation of how Tesla wanted to use this potential difference caused by the Sun and our Earth.
Look at the bottom section. A solenoid going into a bifilar coil with a solenoid wrapped around the bifilar coil. Plus with that action shorting to ground it would allow communication to any device Tesla made to receive such ground impulses.
This is his Niagara Falls example. Find a flow and harness that flow to generate energy and transmit intelligence via that process. The way you open and close the shorted solenoid around the Bifilar dictates the flow of energy through this system and you can attach intelligence in that process as well via the ground as a single terminal electrode.
Does anyone remember the lifter experiments? Why would you think Tesla designed a heavy anchor points for the legs of this tower? As the system charges up and the top cap plate reacts to the potential differences it tries to move towords the higher potential of the plasma above it. Essentially this would fly away or lift towards the higher potential of the plasma above it. Remember plasma is conductive to the higher potentials and gets attracted to that higher potential. Tesla described the center mast to ground was to better grip the earth. As well going deeper in the earth would increase the negative potential as much as going higher away from ground increases the positive potential. This will also increase the potential difference as well between the two plates of this capacitor and should increase the energy output at the Shorted cap and coil around the bifilar going to ground.
My best guess is that to start the process all you need to do is short the spark gap momentarily at position E. Once it is started all you would need is a spark gap system at the takeoff point or cap G position. This would open and close the magnetic clutch Coil C at the breakdown frequency of the takeoff point G as the cap G is discharged across the spark gap not shown. That would open the magnetic clutch and allow the system to ground itself and cause a great current flow though B', B and bifilar coil A and across the ground spark gap. This would charge up coil C and a magnetic field would be built up restricting the flow to ground. This is the oscillator section.
The take off circuit is at G and governed by the spark gap distance and used in the regular method Tesla used for impulses. Lighting and single wire motor could be used there or a regular transformer fed with impulses would convert the impulses to AC for traditional systems to use in the method Tesla has shown to a capacitance or virtual ground.
The heavy winding at the bottom with the cap G and the coil C look to be just an isolated LC.  I may be wrong.
Mags
Magluvin
Quote from: Magluvin on December 04, 2016, 07:47:11 PM
Mags
Its strange.  Just looking at the depiction of the tower, if the cap of the top of the tower is able to produce a spark at the far bottom, a bit underground it seems, happens often enough, then the LC I described as, what it looks like, isolated, then the tower unit as a whole may be a self powered transmitter. ???
The tower pics up charge from the air above and when the spark gap fires, the coil from the top cap to the ground induces the seemingly isolated LC which in turn reinduces the tower coil producing a tuned transmitter effect, and repeat. If the spark is fairly often, possibly sparking at higher freq than one may imagine, then the tower may be like I said, a self powered power transmitter. ;)
Mags
