The 'free energy' spark
Started by pomodoro, January 06, 2015, 02:30:01 PM
jbignes5
 I had the opportunity to get a pdf that kinda explains this process and I took out what I think is an accurate depiction of the whole Tesla system and I also modified it with additional Tesla patented schematics. See what you think about these.
The first schem is from the pdf explaining Tesla's descriptions. The second is using actual Tesla methods.
I made one mistake with the hybred tower. The Tap coil should have a bifilar coil then connect to the cap ball at the end or left open with no mass capacitor( you would probably need a wire out still like a straight whip antenna), just to the left of the NS magnetic spark gap. The secondary is a heavy solenoid around the bifilar primary. This is solely to getting two pulses out of the solenoid as the impulses travel around the bifilar coils. Or could even strengthen the push through reinforcement of the impulse to ground or an antenna. I have not experimented in this direction yet but it is on the agenda.
Of course the original method as Tesla gave to the bankruptcy court should be examined to see what the effects are as well. That is the first picture. That picture was reproduced by me but the original was from the Tesla museum in Belgrade, the book was named "Colorado Springs to Long Island notes".
jbignes5
 When we look at my second picture you get two very important data points.
The 20Kv on the top cap is not paid for by us.
The -15Kv on the ground connection is not paid for by us.
Both are essentially free just like the Niagara Falls analogy and facts about that generating system. The Tower would be needed to transmit the energy harvested from our surrounding environment to people but the generating from those potentials like in the Niagara falls analogy would essentially be done via a flow that could be harnessed in our environment now.
A portable version is also available via a virtual ground system loop.
The plasma is the conductor of our reality we call space. It is everywhere and in everything to degrees. It is highly dynamic in density only. It responds to electrical stimulation and forms the magnetic field which is an organized movement of plasma flows. When we excite matter the plasma flows into matter and the surrounding environment around the matter and increases the energy of that matter via this increased conductance via plasma. It is the reason that matter expands when heated and shrinks when cooled.
Just some thoughts...
Turbo
Quote from: Zeitmaschine on November 06, 2016, 06:15:08 PM
That's an error in reasoning. Because space is »Nothing« by definition, it means »empty room«. But »Nothing« can't have any properties. It's logically not possible.
Well you exist in space as well.
Are you >>Nothing<< ??
Zeitmaschine
No more to say about my preceding statements?
The correct answer should be, clotted/solidified aether, I'm made of.
jbignes5, where can I see a tower acting like a capacitor pulling down plasma from the ionosphere in a Kapanadze video?
But here I can see three more concentric »magic« capacitors in action. Since the sparks of the (eye-candy) Tesla coils can hit those capacitors safely, each of them must have a ground connection. Further more, each of the three yellow output wires is connected directly to one of those capacitors. Conclusion?
Zeitmaschine
Just one more item for the collection: the Hendershot generator. There are two concentric (magic) capacitors each surrounded by a coil. Simply placing an ordinary factory-made capacitor in the center of the coil will do nothing. So we know for sure that this  demonstration has to be fake. Same nonsense here and here (and others). The genuine Hendershot generator worked not because of those fancy wound basket weave coils but because of the homemade concentric capacitor plates inside. Stunning.
