0 Members and 57 Guests are viewing this topic.
MarkE
Quote from: synchro1 on March 25, 2015, 03:43:52 PM
@MarkE,
I said nothing about an "outer ring" of nuts. Imagine a string of beads. Your flux density theory is completely worthless to explain the PMH effect.
If one were to stack additional sets of nuts on top of the first set, then they would link just like the first set.  All that matters is the flux generated by the current pulse through the wire that runs through the center of each plane of nuts.
If you do not understand the explanation, then the problem is probably that you do not understand magnetization curves.  If you really want to understand what is going on hands-on, then what you can do is get yourself an iron U block and strip stock.  Lap the faces so that they are very smooth and flat.  Magnetize the set and then suspend the U facing down, and hang weights from the strip until it breaks free.  So that a few times recording the weight required.  Then apply one layer of Kapton tape to the mating surfaces of the strip stock and repeat the experiment.
MarkE
@MarkE,
The "Impulse Magnetization" effect that's an industrial standard, is an OU effect when the input is measured against the force the permanent magnet exerts over it's life span.
Magnetizing a magnet hard or soft has never been OU.  Force is not energy.  Force * time is not energy.  The integral of: force * ds is energy.
The pressure of the locked nuts generates measurable heat. Doubling the heat in a second set of nuts, with the same joule pulse, would tear a hole through the second law of thermo-dynamics.
No, there is no on going heat generated by the static stress of the nuts pressing against one another.  I suppose you think that your sofa or dining room table heat up the floor, or that your house heats up the ground just by being there.  You have funny ideas.  There is nothing going on here that in any way threatens the Second Law.
Russ has the nuts placed on a board with a hole through it. A second board with a hole and a set of nuts like the first, one over the other, with the wire threaded through both holes, would result in the correct test configuration.
And as long as the wire penetrates the center of both boards/sets of nuts, they will lock together as well, completely in conformance with presently understood physics.
synchro1
@MarkE,
"And as long as the wire penetrates the center of both boards/sets of nuts, they will lock together as well, completely in conformance with presently understood physics".
Looks like you changed your mind! How about a third board/set of nuts? What's the upward limit?
There is no upward limit, because the "Violent Field Collapse" that causes the locking effect has infinite power that is transmitted instantly, as a longitudinal wave, to all points in the Universe through the "Space Time Continuum". The number of nuts has no way to retard the violence of the "Field Collapse"!
Plus your telling us a piece of coal positioned under the sofa leg won't produce a diamond. Lol!
synchro1
@MarkE,
You have the PMH locking effect misunderstood exactly backwards. It's a "Quantum Implosion" effect, not the consequence of "Magnetic Induction".
MarkE
Quote from: synchro1 on March 25, 2015, 06:45:49 PM
@MarkE,
Changed from what?  How big is your battery?  How long is your wire?
You appear to enjoy making things up.
The sofa doesn't make the lump of coal hot.
