0 Members and 47 Guests are viewing this topic.
seychelles
FOR example when an electromagnet is electrically powered up it spin pushed ether outwards in one direction and when the power is switched of ether spring back in the opposite spin hence bemf. a permanent magnet is pushing ether out wards constantly because  of it structural spin resonance..gravity is the brother of magnetism in a different format each atom has has the protons and electrons spinning at TWICE the speed of light AND THE ADDITIONS OF EACH ATOMS DOING THEIR STUFF ADDS UP TO GRAVITY MORE ATOMS MORE GRAVITY.. WHY IS THE ELECTRONS AND PROTONS TRAVELLING TWICE FASTER THAT SPEED OF LIGHT E=MC^2.
tinman
Quote from: seychelles on April 27, 2016, 08:25:40 AM
All you have to do now,is provide scientific evidence that this aether exist,and at this point in time,it has not been detected by any science experiment.
Brad
seychelles
Ether have a tensile strength just like any thing in the universe and a BLACK HOLE is the proof of existence of ether. ether is punctured through because of the mass density of that dead star or stars.. and a black hole is a recycle of the universe and it ARSED end is that what power all the stars of the known galaxies. Because what ever travel in and through a black hole travel faster than the speed of light you do not perceive it until it reaches it different stars destination. that is why in the middle of every known galaxies there is a black hole RECYCLING ALL THAT ENTERS IT POT HOLE. THE FABRIC OF SPACE AND TIME IS ETHER.
EMJunkie
Brad, interesting...
Quote from: https://en.wikipedia.org/wiki/Aether_(classical_element)
According to ancient and medieval science, aether (Greek: αἰθήρ aithēr), also spelled æther or ether, also called quintessence, is the material that fills the region of the universe above the terrestrial sphere.
The Famous Michelson Morley Experiment was supposed to have disproven the Aether, it was a flawed Experiment and has been shown to have been doomed for failure before they began.  Michelson-Morley: The Great Failure:
Quote from: http://www.the-scientist.com/?articles.view/articleNo/8805/title/Michelson-Morley--The-Great-Failure/
He wished the dogged little Dutchman would drop the matter and accept the fact that both of Michelson's ether-drift experiments had been miserable failures. The ether was out there, but at present his instruments were unable to detect its presence. Lorentz, however, was not in a mood to let go of such a lively issue.
Even though it was a failed experiment, it did no good for the Aether. Scientists picked up this NON-Observation as a Non-Existance.
Neil deGrasse Tyson explains the Michelson-Morley experiment excerpt from UNDAUNTED
Michelson Morley Interferometer Experiment. Special Relativity vs Aether
However, the Aether is not dead, even though many would like it this way. Science will do full circle soon enough. The study of Neutrino Science will open these doors.
The best documentary's
    NOVA - THE GHOST PARTICLE - Discovery Science Universe
    4850 Feet Below: The Hunt for Dark Matter
   Faster than the Speed of Light?
   Neutrino - Measuring the Unexpected
   Hunting for Neutrinos
I think it is a fair comment to say what we call Dark Matter, is the equivalent of the Aether. Considering all the descriptions are similar anyway. The Aether is certainly a much better name than Dark Matter.
Looking in the wrong place for evidence is a fundamental floor of Science. Light is not the Speed limit of the Universe. This is only just now starting to be accepted.
   Gravitational-wave rumours in overdrive
Quote from: https://www.ligo.caltech.edu/page/what-are-gw
Gravitational waves are 'ripples' in the fabric of space-time caused by some of the most violent and energetic processes in the Universe. Albert Einstein predicted the existence of gravitational waves in 1916 in his general theory of relativity.
And have we found them?
Quote from: http://www.sciencemag.org/news/2016/02/gravitational-waves-einsteins-ripples-spacetime-spotted-first-time
On 14 September 2015, at 9:50:45 universal time—4:50 a.m. in Louisiana and 2:50 a.m. in Washington—LIGO's automated systems detected just such a signal. The oscillation emerged at a frequency of 35 cycles per second, or Hertz, and sped up to 250 Hz before disappearing 0.25 seconds later. The increasing frequency, or chirp, jibes with two massive bodies spiraling into each other. The 0.007-second delay between the signals in Louisiana and Washington is the right timing for a light-speed wave zipping across both detectors.
How? Yes, with a very large Interferometer, just like the Michelson Morley one, but much bigger and much more accurate!
Quote from: https://en.wikipedia.org/wiki/Gravitational_lens
A gravitational lens refers to a distribution of matter (such as a cluster of galaxies) between a distant source and an observer, that is capable of bending the light from the source, as it travels towards the observer. This effect is known as gravitational lensing and the amount of bending is one of the predictions of Albert Einstein's general theory of relativity
It is well known that Gravity and Light interact together. Gravity Bends Light.
Quote from: http://www.juliantrubin.com/bigten/michelsonmorley.html
Now, if there is an ether wind blowing through the Earth, someone looking through the telescope should see the halves of the two half-pulses arrive at slightly different times, since both light beams travel the same distance from the beamsplitter to the two mirrors, and the one that would have gone the ether wind upstream and back is more inhibited than the one gone across the stream and back. It is the same case as with a swimmer that swims at a constant speed the same distance upstream a river and back and across the river and back - upstream and back time will be longer that the across and back time. It is possible to demonstrate by simple calculations why this difference occurs.
The failure of the experiment, the Michelson Morley Experiment to find what was expected, is not an indication that the Aether does not exist, it is only an example of how, looking in the wrong place for evidence is a common problem in Science.
The Aether is not like Swimming Upstream or Downstream, the Neutrino Videos clearly proves this. There is no Resistance to the Aether, looking for Resistance when there is none is a failure of Understanding, not an indication of Non Existence. So why does Light have a speed limit, what is resisting the speed at which Light Travels?
Quote from: https://en.wikipedia.org/wiki/Measurements_of_neutrino_speed
Measurements of neutrino speed have been conducted as tests of special relativity and for the determination of the mass of neutrinos. Astronomical searches investigate whether light and neutrinos emitted simultaneously from a distant source are arriving simultaneously on Earth.
Hmm, Instantaneous Speed?
Quote from: https://en.wikipedia.org/wiki/Matter_wave
The concept that matter behaves like a wave is also referred to as the de Broglie hypothesis (/dəˈbrɔɪ/) due to having been proposed by Louis de Broglie in 1924. Matter waves are often referred to as de Broglie waves.
Why is the phase velocity of de Broglie waves greater than the speed of light?
The very fact that Neutrinos passing right through the Earth, is enough to say that the Resistance of Light being made to Travel Upstream is an insufficient argument to disprove the Luminiferous Aether:
Quote from: https://en.wikipedia.org/wiki/Luminiferous_aether
A major breakthrough was the theory of relativity, which could explain why the experiment failed to see aether, but was more broadly interpreted to suggest that it wasn't needed.
So, why do we have the need for Dark Matter, what's still missing from Science? Why the need?
Quote from: https://en.wikipedia.org/wiki/Dark_matter
Dark matter is a hypothetical substance that is thought by most astronomers to account for approximately 85% of the matter in the universe. Although it has not been directly observed, its existence and properties are inferred from its various gravitational effects such as the motions of visible matter, via gravitational lensing, its influence on the universe's large-scale structure, and its effects in the cosmic microwave background. Dark matter is transparent to electromagnetic radiation and/or is so dense and small that it fails to absorb or emit enough radiation to be detectable with current imaging technology.
This sounds eerily familiar, do we get some sense of Parallelism with these Theories that cannot be proven either way?
    Chris Sykes
        hyiq.org
EMJunkie
Einstein was not for the Aether, but at the same time, he used an idea that is parallel to the Aether:
    Chris Sykes
        hyiq.org
