0 Members and 68 Guests are viewing this topic.
kEhYo77
Looks like a winner!
It would be nice if you could make a video.
I'd like to know why are you using the LED in measuring the input on the input side. It is not clear right now.
Why the LED is not bright when you measure the input current?
I'll try to make one. :)
l0stf0x
With dc motor the results are more realistic..
I connect the output to a dc motor and I reed 84.5mA and 6Volts -->  5.07Watts  The motor run fast
dc motor directly to battery ..I reed 75mA 3.39V -->2.5425 Watts
The battery voltage alone was 3.51 volts
Video takes time .. And I think there is nothing hidden here
If you place an electrolytic 220uf 25V parallel to the bridge you read 43.5 Volts output..
I ll try to charge the battery with output..
l0stf0x
Not for a reason.. I was checking different loads and I saw big difference with those leds,.. There is something tricky I guess here.. with those leds...Because with dc motor the gain is more realistic
The leds are not bright not because I measure the current but because the current is low. I don't know why ...with multimeter or not the leds are dimmed directly to the battery.
Quote from: kEhYo77 on October 11, 2016, 10:24:54 AM
kEhYo77
Do you have a picture with bright LED and the current meter in series with the battery?
l0stf0x
Not yet and I am away from my workplace to do it now.. Tomorrow I ll do that, and other tests..
I will stick to the dc motor and forget about the leds.. there is something strange going on with this LED pcb. Maybe its the bridge rectifier on pcb .. I really don't have an idea.
I have to test the battery discharge times for both cases.
and to check if I can recharge a second battery or the same battery in closed loop.
After all that .. I will move to more advanced coils setups. I guess the voltage/current will be more if you add copper turns to secondaries. We ll see :)
