0 Members and 101 Guests are viewing this topic.
EMJunkie
So, why are turns important?
Magnetising Turns, Ampere Turns is key to making these devices work! Ampere Turns (AT) = Turns (N) x Current (I) which is also Magnetomotive Force (MMF)
Quote from: EMJunkie on June 06, 2015, 07:52:57 PM
Remember, the objective here is to get these Field's, the Partnered Output Coil's Magnetic Fields, up as high as possible!
Quote from: Guidelines to bucking Coils http://www.hyiq.org/downloads/guidelines%20to%20Bucking%20Coils.pdf Page:2
Current, as you may think, is not stepped down as a result of the Voltage being stepped up.
It is the Magnetic Field and the Change of the Field that invokes Electromagnetic Induction!!! The Impedance of the Coils are a function of the Strength or the Magnetic Fields that Oppose each other!
   Chris Sykes
       hyiq.org
EMJunkie
Hahahaha - Magnetic Compression Study" by Cyril Smith
@Smudge - Don't you mean Bucking Coils?
It's not going to go away Boys!!! I have bought to you, the future, from the past, whether you like it or not!!!
It is high time you all started giving credit to the Legends thorough out History that have kept bring this back to you!!! Before it Bites You in the Backside!!!
EDIT: I need to correct this term: Bucking
Quote from: EMJunkie on May 06, 2015, 08:43:27 PM
The BIGGEST Problem that you (People that don't yet get this) is that Conventionally, BUCKING means no Electric Field on the Output, which is the Conventional idea behind the term Bucking - That's why I don't use the Term!!!
This thinking (Bucking) is Wrong! Period! - Fields Oppose for a totally different reason! I have already explained why - Lenz's Law, Flow of Current. E.G: Magnetic Field.
You HAVE to stop thinking "Driving the Coils with Current" - Think Induction! An EMF is Induced.... Not Wired to "BUCK", the Coils oppose because of Lenz's Law... Wired to Add Electrically, but the Magnetic Fields Oppose...
   Chris Sykes
       hyiq.org
In German: Intensivstation     in English : emergency room
look for the diferent human(veterinaer)body ee/ec graph/-data(-gram) measuring instruments
also MRI/MRA,Tomograph and so on .... !
                                              Life science and (languange/translating) detecting tools
Sincerely
              OCWL
p.s.: think also about the Acaro  http://rexresearch.com/crosse/crosse.htm
                          Dark matter beam winding :vortex//tornado         "windhex"
https://www.youtube.com/watch?v=QCvqYXnoCSU + SLICKAPHONICS
no using Scientology                    but SCIENTELEOLOGY
l0stf0x
Hey all, I have build a simple joule thief using bucking coil arrangement that I wound my self.. It looks very productive and I wanted to ask you if this it is "something"! or if its a common result.
Output from secondary coils are passed through a bridge rectifier to have dc for taking measures. (direct from battery VS through the circuit)
The load is 3 leds on a pcb with a BR, few resistors and a mini electr. cap. (Its the head from a hand crank flashlight)
Batery is a 18650
I made some measures..
Direct the load to the battery: 3.70V --- 0.58mA  ---> 0.2146 Watt
Through the circuit:                4.90V --- 93.2mA  ---> 4.5668 Watt
That's 2028% difference..
The loal direct to battery is very very dimmed..
Through the circuit is so bright that you can't see it directly.. near to burn I guess.
Utopia Now
Hallo l0stf0x
It looks quite good  :)
Can you also show the specific schematic you used  and specialy  very specifics on how you wound the coil or coils   and  number of windings CW  CCW  or the specifics  ... right left    so we can replicate it  and also  take measurements .
And where precisely  you measured.
All the inventors say in the  end  it is all about  winding coils   , about  how you  wind them  !
Very good  Lost Fox  or l0stf0x  :)
