0 Members and 80 Guests are viewing this topic.
EMJunkie
This area I am still learning, the "How to predict a device Mathmatically", this is very hard for me! I thought I had it, but its still not right. Still some guess work involved.
I have done some figures:
Faradays Law:
Area: 7.85398163397448E-05 Meters (m) Squared
Theta: 90 Degrees
B Initial: 0.0001 Tesla
B Final: 0.0452 Tesla
Delta B: 0.000354214571692249 Tesla
Delta T: 1.58730158730159E-05 Seconds
Voltage: 22.3155180166117 Volts
Amperes: 1.48770120110745 Amperes
Where; your POC Coils Turns = 100 each, POC Coils Resisance = 15 Ohms, Flux in the Core = 452 Gauss, Radius = 0.5 cm, Magnetic Field is 90 Degrees to the POC Coils, and Frequency = 63KHz, which is 1/F for CPS.
This Voltage is supposed to be Open Circuit Voltage, not Voltage accross a Load!
Now, using a larger Gauge Wire, dropping the Resistance to 4 Omhs:
Faradays Law:
Theta: 90 Degrees
Amperes: 5.57887950415293 Amperes
Hope this gives you some Idea on what and where to look. I guess this is why I have always shown coils with lots of turns but of a reasonable Wire Gauge.
   Chris Sykes
       hyiq.org
wistiti
Quote from: itsu on October 16, 2016, 05:03:27 PM
Changing the 220 Ohm base resistor into a 1KOhm potmeter (range from 150 Ohm to 1KOhm) does not improve the efficiency.
The frequency changes from 15KHz @ 150 Ohm to 63KHz @ 1KOhm and the input current (input voltage steady at 3.5V) changes from 800mA @ 150 Ohm to 130mA @ 1KOhm.
Measuring the secondaries inductance shows that the uncovered secondary still measures 990uH, and the covered (with the primary) secondary measures 948uH.
So we have an unbalans in the bucking coils inductances due to the primary.
I am thinking of removing the bifilar primary and install it on a free piece of the ferrite rod so the both secondaries will have balanced inductances.
Itsu
Thank itsu for sharing your experiment!
I think rebuild it is a good idea. I have build many of these circuit and i still dont understand why some show good result while others dont...? This is why i think building it ajustable, sliding coil, can save some time. I also think different core configuration, different way of excite the primary have to be test...
For now, the best result i acheive with this poc (bucking coil) as output coil is a reduce primary power when a load is connect on output and on some rare occasion unity of just little over...But for sure this configuration can be much more efficient than a regular commercial transformer....
Many may say my result are discutable cause of my cheap mesure instrument and they are probably righ.
This is why im glad to see folks Like you with great skills and equipment working on it...
The most important, dont conclude if the first build didnt work... Try different way!
Ciao!
EMJunkie
Quote from: wistiti on October 17, 2016, 08:47:29 AM
Ciao!
Hey Wistiti - Re the equipment, this is a stupid excuse from nothing more than Sceptics!!!
Graham Gunderson has shown exactly the same Technology that we have worked with for years and they still even question his Equipment and His work. Now anyone with a Brain that works surely has to admit that Graham's Measurements are perhaps the best and most accurate in History!!!
NONE of these Sceptics can replicate Grahams Work either!!! - Try telling Clarke and Hess they have Bad Measurement equipment, you'll have a Law Suit on your hands!!!
Those people will be the last ones to catch the boat!!! If at all!!!
We know, we can see it, we have seen on many occasions, many many occasions, what we do is not possible with standard Transformer!!!
Using standard Battery Formula's and running the Charge Test we did was one of many experiments that show an excess, so those people, the sceptics, are just being idiots! Let's not forget the many others that also show the same results, Anti Lenz - Yuri Likhovid, using Industry Standard Watt Metres well within their bandwidth, also all the other greats, Don Smith and the many others. All using the Exact Same technology!!!
These people, Arm Chair Know-It-All's are the worst type of people! They are the reason that Dogma exists today! Simply because their tiny brain does not know better! Yet it is them that use the same Metres we use, to take Industry Standard Measurements on known Equipment! Now really, this is Stupid Idiot Behaviour from Jealous Brain Dead Morons!!!
We have tested many different ways, it is not just the metres giving us results that show excess!
   Chris Sykes
       hyiq.org
EMJunkie
Why is it, that NONE of the Sceptics can replicate this work?
The answer is simple!!!
Because they have no idea what to look for, what to Aim for or what they even want from it!!! Blind Alley Ways is what they end up taking, Failing on the first try, and then they proclaim themselves as experts and say: "It doesn't work"
Dogma!!!
None do their Homework, None Listen, none take the time to think properly about it, none understand Simple Electromagnetic Induction, none comprehend Electrical Energy, none understand Lenz's Law, none understand how a Transformer Works Properly, none understand basic Magnetics.... The List Goes On and On!!!
Yes Experts, I know about them well!!!
I am a Student in the School of Life, always will be, my entire life, never an Expert!!!
   Chris Sykes
       hyiq.org
EMJunkie
What the self-proclaimed Experts "Should" be telling you, is: "Some cheap Multi Metres do have a greater degree of In-Accuracy"
and NOT: "It doesn't Work Because you have Budget Metres" or "Ah, its just a Measurement Error"
Any "Expert" using this statement or anything remotely close is nothing more than an Un-Educated Fool that cant think Logically!
This is the Brain Dead, Moronic, Idiot way to think and explain any device!!!
Again, my view on "Experts" are very low becauce of their self-proclaimed Status! Idiots are not Experts!!!
   Chris Sykes
       hyiq.org
P.S: Some may be able to see that I am a bit Cranky about this Dumb Stupid Behaviour! Its got to be evident why by now!!!
