0 Members and 70 Guests are viewing this topic.
l0stf0x
I am not that experienced as you guys, please forgive my silly questions if there are...
Can someone explain why are we using bifilar coil and not a regular coil as a primary?
As we know bifilar coils decrease the inductance of a coil because the windings are wound in such a way as to cancel the each-others magnetic field. Don't we get less magnetic force at the core too?
Have anyone tryed to use as a primary a regular coil?
Also has anyone tryed this circuit with pancake bifilar coil as primary and pancake bucking coils (or bifilar as well) as secondary?
Thanks
gyvulys666
to l0stf0x
interesting stuff which i want to try in near future but with 3 pancake coils one  on one side other on other side and betwean them primary https://www.youtube.com/watch?v=rYNEzVIXDeM
and some random stuf from same guy  -->https://www.youtube.com/watch?v=IxKVftU3w1w
coil have 2 sides  but usualy we use only one :)
wistiti
Lostfox you are completlly righ .
There are many way to create the primary magnetic field. And this one it is not the more efficient one... As all its about magnetic field, we should try different way for creating it.
I have not try with pancake coil. It might be a good idea!
l0stf0x
Gyvulys666 thank you! Nice videos! good info!
Wistiti, I will try pancakes as well :)
EMJunkie
Quote from: l0stf0x on October 18, 2016, 03:03:44 AM
Thanks
Hi l0stf0x, No such thing as a silly question.
The idea/concept here is twofold, Increase Electromagnetic Induction and also reduce the Reflective Magnetic Component back on the Primary. This bit is Lenz's Law.
I really dispise the term Bi-Filar because by definition these coils are not Bi-Filar. Partnered Output Coils are two separate and distinct Coils on the same core. Bi-Filar by definition are Parallel wound, side by side.
Partnered output Coils, it may be worth reading the PDF I wrote: Guidelines to Bucking Coils
Also these videos may help:
Opposing Magnetic Field Interactions - Partnered Output Coils
Self Assisted Oscillation in a Shorted Coil - Bucking Magnetic Field Oscillation
Partnered Output Coils - Why it's Important to have Current Flowing!
Self Assisted Oscillation or Field Effect Amplification of an Induced Rotating Magnetic Field
Explanation of Partnered Output Coils
You can see I have spent many thousands of hours on this Tech. Trying to learn the Interactions between two Output Coils, Partnered Output Coils. My Channel has many more videos, the above are the most important to get started.
In the Video: Partnered Output Coils - Why it's Important to have Current Flowing! you can see at the end, there is an Increase in the Wave Amplitude shown at the end. This is due to an increase in Electromagnetic Induction, More Charge is separated, as a result, the Magnetic Fields opposing, Electromagnetic Induction is Increased!!!
This is a critical principle!!!
There is a Lot to learn, but I always believe, Little Steps for Little Feet is the key, I am still learning, and always will be learning!
You at least have a working device that you can learn from, sitting on the bench, and it's very obviously performing very much better than the average device. So you're well on your way! Use the Oscilloscope to study your wave forms.
Re Pancake Coils, I am not a fan. I think it's more important to study what we have and learn as much from this as possible first. Then move to other ideas later on.
   Chris Sykes
       hyiq.org
P.S: Wistiti is exactly right!!! "its about magnetic field" The Magnetic Fields as we know them is the Key to making this work!
