0 Members and 76 Guests are viewing this topic.
l0stf0x
Hey EMJunkie, you are very welcome, But I did the obvious!
What we do here is for common good.. sharing is the strong base to build.
Mr. Bedini by the way was a great paradigm of sharing.
This explanation from Floyd Sweet fits exactly with the magnet's roll is our system.. the tidal kinetic energy in our case is the magnetic field of the magnet !!
Actually there are 2 cases of how the magnet could be helping in the system. One is the example you post.
and the other is the case of .. the magnet act as stopper of the smaller tidals that are coming from the opposite direction of the ships direction (using your example), something like magnetic diode imagine. Because if you add another one on the same core either by extending the strength of the first one or either applying it on another point on core you get either no change or more input current needed.
This needs testing too :)
But in any case of the two the magnet's field helps.
Thank you EmJunkie, You are leaving library!! You scare me some times ;)
EMJunkie
I am a very happy man to hear that you can see that L0stf0x!!!
Yes, my goal is to try to share with others what I have learned, but not direct others, merely to give guidance or a path ahead, if its what they are looking for. We are all our own leaders and we are all just as important as the next person.
I am a student of life and I try to listen, and I am guided by, all. Some of what I have posted is not always 100% correct, as I have learnt a lot along my path also, but I have always tried to post the most accurate detailed data I can, most all of it has been some result of my experiments.
That Voice within, its very much more powerful than many think! Some follow it, some ignore it.
After turbulent times ahead, we will have such a glorious future! I agree, we are leaving a Blue Print for the future. It really is them that we work for!
   Chris Sykes
       hyiq.org
P.S: A Magnetic Diode is a good analogy! I like that.
P.P.S: If I told you how many times I have read the Floyd Sweet Papers before I understood them you would laugh at me! Its only because I had some understanding of these Coils before I obtained the Papers, that I could understand as much as I have. It works, as we have been told, it takes a lot of understanding and observation, but it works! John.K1 was spot on in his observations with the MrPreva Circuit, this is part of the solution as we already know. The other is a combination of frequency, turns and the strength of the Magnetic field. Mostly Faradays law of Electromagnetic Induction.
itsu
Still waiting for you guys to surpass my 80% efficiency on the simple circuit we started with.
How are you coming along with your builds / results???
Regards Itsu
EMJunkie
Quote from: itsu on November 09, 2016, 04:18:06 AM
Regards Itsu
Hi Itsu,
Back in 2011 I posted results: http://overunity.com/10773/physicsprof-steven-e-jones-circuit-shows-8x-overunity/msg289287/#msg289287
19 times more Electrical Energy out than I put in. I show Scope shots there also.
If you study this closely, there are many correlations to this circuit and Partnered Output Coils, why?
Mosfett Gate Capacitance and Capacitor C1's, Capacitance in the Trigger Coil keep the Coil in a High State for some time during the Cycle, At switch off, where you see the Spike in the output wave, the two coils become Partnered Output Coils.
You can see, there is some similarity, a large sharp Spike in my Sinusoidal wave form, in my scope shots to Graham Gunderson's MIT Scope Shots, but 5 years before, when I was working with Professor Steven Jones, Replicating his work.
You will also see that the Input Current is Sinusoidal in nature, indicating Reactive, Ping Pong Power Component! VR2 plays an important role, this only works if one is not over driving the Coils, Limiting the Current on the Input, so as to not over drive the Coils, Over Driving the Coils presents a Non Working Device.
I have reposted here for your convenience.
   Chris Sykes
       hyiq.org
NOTE: I have only one scope, 2 Channel, measurements were taken separately from input to output. No ground loops were present.
itsu
Huh?  I was under the impression that we as a team would start building the simple circuit that was presented here:
http://overunity.com/15395/partnered-output-coils-free-energy/msg493565/#msg493565
I build severall versions now with a max efficiency of about 80%.
According to comments that is the bare minimum and there should be room for improvements.
Up till now i have not seen any other results from you guys of this simple circuit so therefor my question  "How are you coming along with your builds / results???"
Regards Itsu
