A Practical Guide to ‘Free-Energy’ Devices
Started by Spirit, January 25, 2015, 04:25:33 PM
MarkE
Quote from: profitis on January 26, 2015, 03:55:14 PM
Nickel has a hundred different properties to iron mark E.there is simply no way to predict what will happen with a nickel smotball until a nickel smotball is tried and thoroughly tested.
So your approach is to search for nano-genies under grains of sand, one grain at a time???  How about starting with a working hypothesis, such as:  "I expect this SMOT to work because of (fill in the blank) property of the ball changes the: ( static magnetic field or gravitational field ) in such a way that it is no longer conservative.  I can therefore destroy energy (or send it from this world) by traversing one closed path, and create energy (or bring it into this world) by traversing the reverse path."
profitis
its density is different.its permeability is different.its friction (vanderwaals) is different.its curie point is different.its rate of expansion/contraction is different.its crystallography is different.its smell is different.its heat capacity is different its electron configuration is different.all of these things can either contribute or deduct from the nickel smotball performance.all properties.all hundred variables.the moment it flys past the top magnets is where any of these properties can catalyse a 2lot bust.its a coin toss and its woth tossing @mark E
MarkE
Quote from: profitis on January 26, 2015, 05:48:45 PM
So do you really do think it's worthwhile to just randomly test hoping that some random input parameter change will affect an experiment without first forming a hypothesis to test?
profitis
Nothing wrong with that approach no @mark E.if the nickel smotball results in unusual behaviour then we can begin to dive into the cause.it will invariably have something to do with the way heat is exchanged with the environment before,during and after flipping of magnetic domains.the nickel smotball is one smotball that should be tested sooner or later
vasik041
Quote from: TinselKoala on January 25, 2015, 08:03:22 PM
...because of the sun evaporating water and driving weather which produces rainfall which then runs down to fill up the reservoir. The energy comes from the sun, not gravity.
Hi TinselKoala,
I have a question which you perhaps could kindly answer:
before rain fall, water vapor condenses and same amount energy which was used to evaporate water is released, isn't it ? Why we need Sun for this process ?
Thanks,
Vasik
