Gadolinium Magnet Generator.
Started by synchro1, April 03, 2015, 02:02:04 AM
ekimtoor1
Quote from: profitis on April 14, 2015, 11:11:55 AM
That's the statement yes. disgrace to the human race.forget about the camera for now ekim there's hundreds of setups I have in mind.do you possess a votmeter/ammeter that can measure down to a few microamps/millivolts
Yes, pretty sure.
profitis
Ok.the first series of experiments will be to try detect a direct thermoelectric voltage at room temperature.please let me know the moment the coins arrive in your hands ekim.
ekimtoor1
Here they are.  $50 meter from Home Depot.  Two Gadolinium coins .999 pure, 3.4 grams, slightly smaller than a Nickle in diameter, not quite as thick. They are in airtight plastic coin cases just like you'd use for currency coins. My first experiment was to suspend the coin in the case and hang a few noes from it.  About an hour later they had not fell away. So probably means it must be in direct contact, ??
Anyway on with the show, the players are all here I think!
ekimtoor1
Everything is here. $50 meter from Home Depot, can measure microvolts.  Two Gadolinium coins .999 pure, 3.4 grams, slightly smaller than a nickle in diameter, not quite as thick. They are in airtight plastic coin cases just like you'd use for currency coins. My first experiment was to suspend the coin in the case and hang a few neos from it.  About an hour later they had not fell away. So probably means it must be in direct contact??
ekimtoor1
Ok sorry about the pic. I have apparently fallen into the same trap as others have. Was sending from my iPhone and that's the default result. Can one delete the attachment once posted?  Sorry if the question is redundant...
