Friedrich Luling Magnet Motor
Started by DreamThinkBuild, July 05, 2015, 05:31:08 PM
Floor
   and
another magnetic force neutralization by balancing forces @
              https://www.dailymotion.com/video/x59r978
Floor
A fourth variation of magnetic force neutralization.
   @ https://www.dailymotion.com/video/x6gzr2q
      PS
        Nice build UFopolitics
Floor
This type of device could produce work from permanent magnets, only if the energy
present as the shearing apart (by repulsion) of a given two magnets,  is greater than
the energy present in the direct pulling apart (against attraction) of those same two
magnets.
  see...
https://overunity.com/18551/magnet-shear-to-direct-pull-work-ratio/msg548052/#msg548052
  best wishes
        floor
Ufopolitics
Quote from: Floor on September 22, 2021, 08:53:20 AM
      PS
Thanks Floor!
I was trying to keep it as simple as possible in this first video, just a "teaching tool"...however, the air piston does an "overkill" job...meaning too much strength (65 to 70 Newton Meters) plus too much distance in the stroke (1/2 inch) , an excess not really required by the setup of the two pair of 1/2 inch 52 grade cubes Neos...
I recently purchased a small Push-Pull Force Gauge Dynamometer, and am so glad I got this tool!!...I believe without it, is like flying a plane without gages....blind.
I have seen your builds and tests, very impressive!!
I just wanted to share some of my experience about my setup...
There is an "Angle point" in the alignment of Bisectors between Stators and Rotor Magnets, where the separation force to pull one side apart reduces considerably by just one to two degrees off, as it becomes part of the rotation sense force of rotor in favor of those degrees...
In my case, I love Mechanics, and so I believe very much, that by using the correct lever-fulcrum laws and compound levers, plus springs, plus triggers effects to "assist" the Pull apart required force could be achieved without pneumatics....and it is so simple math...measure the magnetic force executed by turning neutralization off (separate magnets at opposed end) it will tell you if the force to separate is smaller or greater than the propulsion force...then it could be achieved.
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Floor
To the best of my ability at this time, this ...
gives a net gain in mechanical work out to mechanical work in.
In other / my "own" designs, I am not as yet, thoroughly convinced there is
a net gain.
Thanks for your sharing and explorations.
As an aside..
@ all readers...
I would very much like to see some replications of the shear to direct pull
measurements.
   best wishes
             floor
