Friedrich Luling Magnet Motor
Started by DreamThinkBuild, July 05, 2015, 05:31:08 PM
Ufopolitics
Quote from: Floor on September 25, 2021, 01:57:48 PM
To the best of my ability at this time, this ...
https://overunity.com/18551/magnet-shear-to-direct-pull-work-ratio/msg548052/#msg548052
gives a net gain in mechanical work out to mechanical work in.
In other / my "own" designs, I am not as yet, thoroughly convinced there is
a net gain.
Thanks for your sharing and explorations.
As an aside..
@ all readers...
I would very much like to see some replications of the shear to direct pull
measurements.
   best wishes
             floor
Hello Floor,
Do you believe in LÜLING MOTOR is used the Magnet Shearing method?
And if you do, can you show any proof on video, frame or image which could lead Us to think so?
IMHO, the movements that we clearly see on that only video, show a Reciprocating Mechanical Movement, whether on the right side of screen shaft plus pivoting bracket, as also on the Heavy Metal Arc, which pivots also back and forth...
Plus, when we do shearing of one magnet in attraction (or repulsion), in a ROTARY SYSTEM, the separated Magnet will always have a Field influence on the Rotation Magnets on Rotor...whether it is a Cogging by Repulse or an Attract, it will always be a negative outcome...a magnetic friction opposing rotation.
Versus Magnet Separation...where magnet just pull apart backwards, away from rotary magnets...not creating any friction.
This is only and just my opinion.
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Floor
Quote from: Ufopolitics on September 27, 2021, 10:10:53 AM
Hello Floor,
Cheers
Ufopolitics
1. User LankaIV is a highly valued member here at O.U. forum.  Not appreciated by
everyone, but certainly, by myself and also by very very many others.
We all flame some times / it happens, but please do your best to
show more self restraint.  Let us do our best, to not let our ambitions
out stripe our humanity.
2.  I don't know if the  LÜLING MOTOR actually works or not.
Perhaps it was dependent upon out side energy as much as it was
upon magnets. Who can say with certainty ?
We don't even know what / where the polarities are.
3. I had no theory as to how it works before your presentations.
4. You must I assume, all ready be aware, that any all magnet motor is
considered by science proper as an impossibility, do you not ?
"Plus, when we do shearing of one magnet in attraction (or repulsion), in a ROTARY SYSTEM,
a magnetic friction opposing rotation. "
Except for added friction, vibration and so on, the work, as both, done and lost, is net zero in
simply rotating one pole past another.
edit
If it is in fact true that the net, work, as shear is greater than the
direct separation work, there is some, possibility here.
best wishes
   floor
ramset
Gentlemen
I believe this has already been mentioned
However
Note to UFO politics
Here at this forum there was a section set aside for builders sharing their work
It allows management of contributions by host/builder ( would be UFO in this case)
Sometimes it is necessary to limit overzealous off topic contributions in "builders boards"
And host ( UFO?) can manage,organize or remove inappropriate contributions.
For clarity these sections once established are like separate forum areas that can have multiple
Threads !
I highly recommend this for builders
Respectfully submitted
Chet K
Ps
I will be sending Stefan a note later on another topic
If you like I can let him know to watch for request ( he is always having many ongoing projects
And does get overwhelmed with requests at times, this however should go to front of list if requested
IMO
People who take the time to build and share are the most valuable asset the community could ever have !
And their time should never be wasted or disrupted!
Not just one mans opinion...
Thanks Grandma
Floor
Thank you Ramset !
@ ufopolitics
Ramset has just made you an offer. Final decision is up to
Stephan H. and of course to you as well.
      PS
Here are my guide lines in my own board which the forum has
graciously provided for me to use, and in which I do my best to
first observe the over shadowing O.U. forum rules.
https://overunity.com/18496/un-hassled-exploration/msg545850/#msg545850
  best wishes
            floor
Floor
Let me try to imagine ...
What would it be like if
1. I were not only fluent in several languages as well as having considerable
capacity to communicate in a variety of others
                            but also
2. researching in 6, 7, 8, or more diverse fields of physics and alternative energy ...
                                               SIMULTANIOUSLY
                             while also
3. communicating with others, but mostly providing links, related to their discussions.
I'm not, but I do know someone who frequently is.
As it is, my own communications / explorations, far  more often than I would like,
some times blur into one another.  Its due to the diversity of the interactions and
methods I am simultaneously engrossed in.
And to think, this is in just the one area (magnets) I do builds in, and in a single
language.
Yes ! I sometimes loose track of, as to which and to what and with whom.
Is it any wonder that when someone is engaged in much more, they might frequently
get off topic.
               Hey !
But let me recommend that you don't just automatically assume anything is off topic either.
