Friedrich Luling Magnet Motor
Started by DreamThinkBuild, July 05, 2015, 05:31:08 PM
rstergar
here is my new idea...
https://www.youtube.com/watch?v=SLTESkXFSr8 - but when I put magnets inside shielding rotor it is hard to rotate.. it has sticky point...
so I came up with new idea:=
https://www.youtube.com/watch?v=QWDlUEB3h98 - but still sticky point .... so now I have a new idea...
i will fix magnets with rotation shielding...so everything will rotate...
I will update ;)
dom444
here is a simple way to make an attraction motor based on Fredrich Luling principal using an electromagnet to break the magnetic lock.
you can ad one electromagnet assembly for each magnet for more power and capture the back emf with a diode as well.
As a matter of fact you can multiply the magnets and attractor assemblies into a very powerful motor with little power to run.
I just noticed this is a Bedini machine with attractor plates to give power to the wheel.
dom444
here it is modernized,
I have tested the electromagnet attractor steel piece combination and it 100% works test it yourself?
this design could also be optimized with pulse width control of coils to further reduce consumption, back emf could charge another battery while in use like Bedini motor as well.
Also notice that this design produces high amount of torque when magnets are attracted all at the same time I have not built it yet but I am sure it will be a good performance design.
doktorsvet
doktorsvet
