'Impossible' rocket drive works and could get to Moon in four hours
Started by Pirate88179, July 29, 2015, 01:12:10 AM
MarkE
Quote from: gravityblock on August 12, 2015, 04:33:48 PM
The force is zero, the acceleration is zero, and the velocity is zero.  Below is a snapshot of the results from an acceleration calculator.  I'm using the Planck time of 10-43 for the time interval in our equation.  However, we can use any time interval and it doesn't change the result.  So, we plug in the calculator's result of 0 into our force equation and we have F = m x 0, F = 0.  Acceleration only applies to a moving object.  Acceleration doesn't apply to a stationary object.  Saying the acceleration is at the maximum is another inversion of the truth.  Saying the Force is at the maximum is another inversion of the truth.
@minnie:  How many times will you allow yourself to be tricked by the same trickster?  Here's my motto, "Trick me once, shame on you.  Trick me twice, shame on me".
Gravock
From AC:
QuoteWhen the velocity is zero the acceleration is zero however the force which is the cause of an acceleration is maximum.
F=mA still applies.
allcanadian
@Gravityblock
You are correct because the correct statement is a Net or unbalanced Force is equal to Mass times Acceleration. So yes obviously the Force acting on the mass is the sole cause as to why the mass moves and when the velocity changes we call this an acceleration. If the mass is not moving then there is no acceleration, thus the statement F=mA is false and Net F=mA is true.
AC
gravityblock
Quote from: MarkE on August 12, 2015, 05:01:40 PM
F=mA still applies.
Acceleration only applies to moving objects, thus F=mA only applies to moving objects.  However, if you want to apply F=mA to a stationary object (which is absurd), then fine by me.  It doesn't change what it is, and that is an acceleration of 0, a force of 0, and a velocity of 0.  It is what it is!
Gravock
MarkE
Quote from: allcanadian on August 12, 2015, 05:06:10 PM
@Gravityblock
You are correct because the correct statement is a Net or unbalanced Force is equal to Mass times Acceleration. So yes obviously the Force acting on the mass is the sole cause as to why the mass moves and when the velocity changes we call this an acceleration. If the mass is not moving then there is no acceleration... obviously.
AC
That is not always true.  Very often it is false.  Please avail yourself to a primer in differential calculus.
MarkE
Quote from: gravityblock on August 12, 2015, 05:08:59 PM
Gravock
That is worse than wrong.
