Dr. Stiffler's "New" Quantum Energy Reciever.
Started by synchro1, August 05, 2015, 08:20:49 AM
tak22
Rfacts,
The link still works for me but is slow at about 20 seconds to load. I've converted it to PDF and attached it:
MarkE
Quote from: synchro1 on August 06, 2015, 10:25:50 AM
@MarkE,
Flashlight shaker circuit! I'd bet any amount of money that a section of thin walled copper water pipe with a diametrically polarized tube magnet positioned snugly inside would generate the same kind of current as Stiffler's setup! It's important that the field's at 90 degrees to the conductor face. The connections would probably both attach to the copper pipe.
You need to make sure that the secondary is not shorted as a contiguous copper pipe would be.
synchro1
Quote from: MarkE on August 06, 2015, 04:44:00 PM
@MarkE,
Danial McFarland Cook recommended "Spiral Copper Ribbon" up to two feet wide, to replace the copper wire in his battery. This copper ribbon wraped directly over the dielectric tube housing the magnet core in place of the wire coil.
pomodoro
Quote from: tak22 on August 06, 2015, 03:08:24 PM
Rfacts,
Thanks for the PDF, very interesting.  Someone here should try to  replicate the continuous LED driving system.
If a plastic insulator is between the metal plates as shown, and the plates are also separated by a thin plastic sheet from the magnets, then the magnets can't act as short dipole antennae, picking up stray signals.
All wiring must be kept ultra short and magnets must not in any way be prone to movement as this could generate a small voltage as the capacitance between the plates changes with pressure.
Then, if it can be shown to work in different environments, we could say that something special probably happening.
synchro1
Stephan selected this for a show case video: Stiffler shows how a ceramic capacitor works in place of the copper plates!
https://www.youtube.com/watch?list=PLC7684829E98CAD74&t=22&v=JBqSEEGGBWE
Tesla explains how his "Serial Bifilar" acts as a capacitor in his patent. Now we see the same two components as the diametric tube neo magnet inside the bifilar solenoid bore hole (Fields on the perpendicular).
Magnet fields at 90 degrees to a capacitor face. The conditions are identical!
