HIDDEN FREE ENERGY TECHNOLOGY IN BIBLE
Started by that_prophet, October 11, 2015, 08:17:15 AM
citfta
that_prophet
Quote from: citfta on October 16, 2016, 04:52:24 PM
Your device is useless!
I love how you intricately explain away all of my detailed descriptions
It sure shows how your argument is so much more RIGHT
free energy is done using pulleys
http://free-energy.yolasite.com/
It uses the simplicity of it not taking 100 times as much force turning a 100cm circumference pulley, as it does turning a 1cm circumference pulley, yet you get 100 times more LENGTH OF MOVING BELT to work with. If you run the 100cm of belt by any # of 1cm circumference pulleys, you would gain the # of mini-pulleys times the multiple of 100 units of AC electricity.
THAT IS WHY I CALL THIS AN AC ELECTRICITY MULTIPLIER
Lenz law sounds like something electronic, when this works om simple pulley mechanics = 100cm circumference pulley only turns once
+ this gives you 100 turns, X,(times) the # of 1cm circumference pulleys that you attach.
If you attach AC generators to each of these 1cm mini-pulleys,
you would gain 100 units of AC electricity, for every 1cm pulley that you attach.
This could be massive amounts of free AC electricity,
if you added 10's of these mini-pulleys then you would gain 1000's of units of AC electricity,
all done with one spark of DC current, (practically zero)
that_prophet - Re: use pulleys to multiply total # of rotations = AC electricity
Quote from: citfta on October 14, 2016, 01:05:13 PM
I don't understand how you can be so dense.  You have had numerous people tell you that your idea will not work.  That is because we actually have experience working with motors and generators.
REPLY BY ME
I don't understand how mankind be so dense, to not see that this use of pulleys does not involve torque, but simple multiplication of rotations = multiplication of AC electricity. The AC generators are just winding up massive voltage, to turn over your DC motor, only the once, + no current, as you only need one spark to have this self powering.
Now try and tell me that you would not be able to get one spark of DC output,
when you have 1000's of units of AC electricity to work with
citfta
MOTORS DO NOT RUN ON A SPARK OF ELECTRICITY!!  They run on current that comes from a generator that requires torque to turn it.  Follow the links I gave you and try to learn something.
that_prophet
if you attach a 100cn circumference pulley to a DC motor
it only takes one spark of DC current to rotate DC motor one full rotation.
this would give you 100cm of moving belt to work with
now if you run this length of moving belt past 1to10 mini -pulleys.
of one centimeter circumference with AC generators attached to each pulley then.
you would get 100-1000 units or cycles of AC electricity.
these are free running AC generators=(as no load is on them)
all of these generators are running with zero load = no electricity being used
just the fluid friction of the bearings is your only wear or load-type
but you could use magnetic bearings + have practically zero friction
so all of these AC generators are just winding up massive voltage
which can be accessed as potential  = ability to do work = available current in load
you have just made your first self powered set of running AC + DC generators
that you could tap power off of + the more mini-pulleys with AC + DC electricity
(now.... don't you think that you could be able to get one spark of DC current)
( out of the 1000 units of AC electricity that you have for an output)
(this would make this unit a self powering mechanism = perpetual motion)
(+ this could be producing an unknown amount of AC + DC electricity)
I happen to be Born Again + want this super simple free energy technology out
before the first Door closes for Christ to return in the clouds by or before 2019.04
It warns us that no one knows the day nor hour... but it says that we will know
when it is near... near to what? maybe the door.... as we can know "even at the doors"
This way the Tribulation Saints have it to keep warm in our cold Canadian winters
even off the power grid. (remember fires would give away your position)
Doors are plural because He does show up twice = Rapture + at end of Tribulation
that_prophet
THIS UFO TECHNOLOGY IS IN THE BIBLE = EZEKIEL 1:16
Free energy is as simple as using pulleys to multiply rotations
+ multiplying AC electricity with multiples of both size and #'s of pulleys
= https://free-energy.yolasite.com/
- this is so super simple,
that we should be ashamed of allowing satan
+ his fellow evil spirits, to have kept it hidden
for so long = ever since Ezekiel 1:16
- "a wheel in the middle of a wheel",
where it was the first simplistic described how a UFO motor worked in the Holy Bible,.
You only pay one small bit of DC current
to rotate 100 cm circumference pulley one single time,,,,
+ through running the 100 cm of moving belt,
(which came off the circumference of pulley)
+ running it by 10 of the mini- 1cm circumference pulleys
+ attaching AC generators to each pulley,
you can multiply your AC electricity to 10X100=1000 cycles of AC electricity
,,,,,,,,,,,,,,,,,,,,,,,, all for the cost of one spark of DC current
=(just enough to rotate your DC motor one single time)  .  .  .   .  .  .  .  .  .  .  .  .  .  .  .  .  .  .   .  .  .  .
<<< NOW TRY + TELL ME THAT YOU CANNOT GET ENOUGH VOLTAGE FROM THESE 1000 CYCLES OF AC ELECTRICITY,,, + ONLY THE ONE SPARK OF CURRENT, THAT IT TAKES TO ROTATE YOUR DC MOTOR ONE SINGLE TIME >>>
(I hope this makes you realize reality, + how powerful spiritual warfare is going on all around you every day)
YES,,, GOD IS REALITY,,, + HE IS COMING BACK BEFORE 2019.04=Door –(in air for all born-again who are looking for His Coming)
although we are warned that "of that day and hour knoweth no man"-Mat 24:36,
we are also told that we can "know that it is near, even at the doors"-Mat 24:33
Just think of it this way, you are only putting in one small bit of DC current,
Enough to crank over your DC motor once, with a 100 cm circumference pulley attached,
+ through simple pre-school  pulley mechanics, of running this 100 cm of moving belt,
that comes off the one rotation of your 100 cm circumference pulley,
Past 10 mini-pulleys of 1 cm circumference, with free running AC motors/generators attached,
+ you will get 10 X 100 = 1000 cycles of AC electricity.
All for the cost of DC current to rotate your DC motor one single time = only one spark
http://decimationofthisevolutionfairytale.yolasite.com/
http://my2020vision.yolasite.com/
http://doorschristmustpassthrough.yolasite.com/
http://aliensandghosts.yolasite.com/
