HIDDEN FREE ENERGY TECHNOLOGY IN BIBLE
Started by that_prophet, October 11, 2015, 08:17:15 AM
that_prophet
GEMs could be used to electrically convert h2o into hydrogen fuel + O2 to have the fire power,
Yet you still have a GEM to convert bad carbon monoxide or dioxide back into O2 + carbon
That way we could have the instant power of the combustion engine,
and still have it in a way that covers up most of its polluting characteristics
This technology is super simple, by just working on the mechanical effects of it not taking 1000 times more electricity to rotate a large 1000cm circumference pulley as it does a 1cm circumference pulley. Yet you can get 1000cm of moving belt off your large pulley, which if you run through one or many 1cm circumference mni-pulleys, thereby multiplying your rotations by 1000 times the # of mini-pulleys that you choose to attach. If you simply attach AC generators to these mini-pulleys, you would be multiplying massive amounts of AC electricity.
Every household could have one or many of these GEM power supplies in it.
-   One for every voltage, OR
-   One for every room
As these mechanisms are simple to build
- Not very costly for parts
- - 1 DC drive motor, + at least I AC generator + belt to connect them
- - One full wave bridge rectifier for every AC generator
- - Wire, enough to go from your AC motor(s) to you rectifier(s) + to DC motor
- - - Then you need to connect wire leads from your DC output of your rectifier
- - - - As well as your AC output motors, (just in case you need an AC output)
- - A small amount of Sauder + flux
- - + some metal, wood or plastic, to construct framing for the mechanical parts
- - - of this Miraculous mechanism
We could even put them in our electric cars
- + no more plugging your car in to gain a charge from your house 120V power,
- but we could
- - plug our car's in, to power your house,
- - - with a little voltage conversion
Description of how to build a GEM = Geometrical Electricity Multiplier
. . . . . . . . . . . . . . . . . . . . . <<<free energy machine>>>
--------------------------------(AC motor=AC generator)-------------------------------
You start with a large (100cm circumference) pulley + you attach a DC motor to the center shaft of it
Then you need at least one small (1cm circumference) mini-pulley,
(the more the better) = More generators = higher current capability
<<because more AC generators=higher capability of current flow>>
Then you would need to build a framing system to hold the
-   motor + generators in alignment for the belt to run smoothly
This could be made out of whatever you had in supply,
-   (1)-wood + nails + screws,
-   (2)-metal strapping or lengths of iron rods,
-   (3)-plastic rods + glue
I say that you need a belt, but in reality you could use a strap, elastic, rope or even tied length of string, to connect your large pulley + your mini-pulleys together.
- pretty convenient, for the many Tribulation Saints, who cannot buy anything without the Mark
http://free-energy.yolasite.com/
Other possible names for the letters of GEM
- God's Energy Mechanism
- Good Electricity Maker
It only takes one spark of DC electricity to rotate a DC motor once. If you attach a 1000cm circumference pulley, this will give you 1000cms of moving belt. If you run this length of belt through 10 mini-pulleys of 1cm circumference, + attach AC generators to them, you would get 10,000 units of AC electricity
THAT'S ONE SPARK OF DC ELECTRICITY IN = 10,000 UNITS AC ELECTRICITY OUT
(please, try to find a way around this AC electricity multiplier)
Torque is not a problem,,, as these generators are only winding up massive voltage, which is exactly what we need to rotate your drive motor, and practically no current = (only one spark)
This is GOD 's Gift to mankind + as well as the natural world around us
This was Given to us way back in Ezekiel's time, (Ezekiel 1:16)
- yet evil spirits have kept this Gift hidden all these years
- Just look at how ridiculously simple this technology truly is,
- and ask yourself just how gullible we were,
- to not see through the evil spiritual warfare that was hiding it from us.
You can seemingly break the laws of thermodynamics, simply because it does not take 100 times more power to rotate a 100cm circumference pulley than it does to turn a 1cm circumference pulley. They both take the same current = one spark of DC, the larger one only take a slightly greater voltage. You are gaining 100 rotations of an AC generator. These are practically free running, as they are only winding up massive voltage. The physical resistance only happens when you are taking power out of it = voltage times current times duration of time
that_prophet
- but we could
that_prophet
STILL SHARING
I don't know how anybody could miss this FREE ENERGY GEM
You are using the massive amount of moving belt, that you get from your large 100cm circumference pulley, to run through 1 to 10 to as many as you would like, mini-pulleys of 1cm circumference. This way you are using the mechanical slight of hand, to multiply the total # of rotations, thereby you are multiplying your amount of AC electricity.
Evil spiritual warfare has kept this super simple way of multiplying our AC electricity for what seems to be forever. Now please, let us break off this blindness that we were under, and now let us see this free energy:AC electricity multiplier for the Blessing that it is.
SO,,, ISRAEL'S 2520 DAY PEACE TREATY MUST BE SIGNED BY OR BEFORE 2019.04 + (.04 X 364.25 = 14.57) OR  January 14, 2019 is the date of when the door closes, on the prophecy about the 70X7's.
I've always called this whole 7 years the tribulation, but I have just recently learned that only the last half is the Great Tribulation.
http://doorschristmustpassthrough.yolasite.com/
http://2020vision.yolasite.com/ My other, better written site about the 20-20 Vision that He Shared with me, seems to have a bug in it, and is transferred out of immediately.
How can we ignore the blatant conflict of logic, knowing that there is only millimetres of space dust on the moon's surface, when the EVil_sOLUTION books,(isn't it amazing what adding the "il_s" of this world system can do to the meaning of evolution) that they cram down our children's throats, try and tell us it's billions of years old. Especially when they boast these religious claims of our Humanist overlords, is supposedly plain factual truth, which they turn their nose, at anybody who can't see the obvious truths of nature. Yet if you took the yearly deposit of space dust on the moon's surface, and ever multiplied it by millions, you would get many meters of dust for a thickness.
I thought us Christians wanted Christ to come back...... 2 things are needed before He arrives both times. First His Bride MUST prepare itself to be spotless,,, before He arrives in the clouds, to rapture us. Then Israel MUST accept + ask Jesus back, before their King Returns to earth, http://beliefstoliveby.yolasite.com/
AlienGrey
Where is the hidden free energy in the bible, and what bible are you talking about ? remember the king James version id full of mistakes, (like the 'Red Sea turned out to be the Sea of Reeds') and Mount Sinai has turned out to be mount Edna in Turkey) and why is it everyone goes back to the Jewish version for clarity in dating and archaeology finds that turn out to be natural phenomena ?
that_prophet
free energy is done using pulleys
It uses the simplicity of it not taking 100 times as much force turning a 100cm circumference pulley, as it does turning a 1cm circumference pulley, yet you get 100 times more LENGTH OF MOVING BELT to work with. If you run the 100cm of belt by any # of 1cm circumference pulleys, you would gain the # of mini-pulleys times the multiple of 100 units of AC electricity.
THAT IS WHY I CALL THIS AN AC ELECTRICITY MULTIPLIER
