HIDDEN FREE ENERGY TECHNOLOGY IN BIBLE
Started by that_prophet, October 11, 2015, 08:17:15 AM
that_prophet
PLEASE ALERT THE WORLD ABOUT THIS HIDDEN TECHNOLOGY
((( NEWS of this ancient technology will change the world as we know it)))
I have the MOST IMPORTANT NEWS
to share with you + this whole world. Unfortunately this NEWS has two sides to it, one is the best, most awesome, and the other one is the most seriously scary. Yes, of course I will tell you the best half first. This best NEWS is that FREE ENERGY http://free-energy.yolasite.com/ is easy to be produced, and can + will even lead to anti-gravity. Yes, that's right, this free electricity multiplication technology will eventually lead us to a way to even defeat gravity. (proof = this tech is found in our Holy Bible, where it is describing the workings of a UFO motor)
This FREE ENERGY technology is soooo easy to explain + use, as you only have to put one spark of DC electricity into this Electricity Multiplication mechanism. That is because you only have to rotate your DC drive motor, with a 100cm circumference pulley attached, one single time. This large pulley has to be attached to a belt, rope, or even string,(in a pinch) strapped around it, that is pulled through ten of the one cm circumference pulleys. Each of these ten mni-pulleys, has an AC generator attached to it, producing 10 X 100 = 1000 units of AC electricity = sparks. This free energy technology works with only putting one spark of DC electricity in, which returns you 1000 sparks, units of AC electricity out. These 10 AC generators all turn easily, with no load on them. (except the load of your one DC drive motor + this is divided by 1000 output sparks = practically zero)
- (Of course you will have to connect your AC output through a full wave bridge rectifier, to convert from AC to DC, then plug your DC drive motor into this output)
Now I must tell you the bad half of this new FREE ENERGY technology. Since this technology is so simple to build, use + understand, then there MUST be a bad-evil influence that was hiding it for all these thousands of years, since Ezekiel 1:16 was written at least. How else can you explain this super simple free energy technology being hidden from mankind for so long. Yet, even this sad news has a shinny lining to it, because our universe has everything balanced, this means that there is also a good force to counteract these evil forces. Yes, there is a God, and Ezekiel 1:16=(a wheel in the middle of a wheel.), along with many other fulfilled prophecies, (please read Armageddon by Grant Jeffrey) proves that He Is the God of our Holy Bible. http://beliefstoliveby.yolasite.com/
This God of our Holy Bible, is so awesomely good, that he has given this end-time Joseph-(that_prophet) free energy, along with other important pieces of information, to share with our world, (like "I AM" is the name of God), just before the final 7 years of Tribulation. This Tribulation MUST start before 2020, http://2020-vision.yolasite.com/ + http://doorschristmustpassthrough.yolasite.com/ (2019.1 = when the door closes on our generation, which we are told that we are allowed to know, in (Mat 24:33) just before He assuring us that "But of that day and hour knoweth no man" (Mat 24:36)
(( PLEASE COPY + PASTE THIS TO EVERYBODY YOU KNOW ))
I love my Father
He teaches me all that I ask
I hope that I maybe able to shake up this world
I want to dissolve this evolution fairytale
I would like to know how these scientists explain
how does our moon remain in orbit
with the constant addition of space dust
we do not hear much about space not being empty
but it contains a steady stream of dust partials
messing up the trajectory of its orbit
+ why is there only about 6000 years worth of dust on the moon
(our moon is GOD's Creation hourglass = proof positive age of earth)
possible lame excuses
Was the space dust just a recent happening – why?
Was there a space storm that blew the dust off, every few thousand years
After a few thousand years, it solidifies + becomes part of surface
The sun burns it off, with extreme solar flares, every few thousand years
http://aliensandghosts.yolasite.com/
http://decimationofthisevolutionfairytale.yolasite.com/
http://evolutiondebate.yolasite.com/
http://myiqchallenge.yolasite.com/
tinman
You need to be banned from this forum for spluttering you rubbish all over the place.
Spamming a good forum with your rubbish-->have you nothing better to do
Some more communal wine perhaps ;D
that_prophet
This gets around your thermodynamic law of power out always being less  than your power in, by switching to the drastic geometrical gain of rotations from a large 100cm circumference pulley, to small one cm circumference = 100 multiplication factor of rotations.(which is how AC electricity is made) This is based on the mechanical ability of one rotation of a 100cm circumference pulley giving you a belt, strap, rope or even tied length of string, in a pinch, giving you 100cm length of moving belt. Then when you run this length of belt through one to ten of one centimeter circumference pulleys, you would get between 100 – 1000 rotations = cycles of AC electricity, if you attached AC generators to these mini-pulleys. That is one spark of DC electricity, could give you 100 to 1000 cycles of AC electricity. HOW COULD YOU NOT GAIN MORE ELECTRICITY THAN YOU PUT IN. These 100-1000 rotations of your AC generator are not hard to rotate, because they are just winding up massive voltage, and only need to generate one spark of current, as a DC motor only takes one spark of DC electricity, to turn over your motor the once. This massive voltage that you are winding up not only is more than great enough to push over your DC motor once, but has lots more, to help you drive whatever motors that you want to plug into your AC or DC motors output.
that_prophet
I was thinking that this is so simplistic, that I was hoping that all of the evil spirits in this vast universe, could not find a way to poke holes in it. But I guess that those enemy forces still have a key word, torque, that strikes doubt in our unbelieving souls. How can I put this any clearer, these AC generators are just being used to wind up massive voltage. All of these many AC generators together, doing their massive rotating, only need to generate one single spark of current, (practically none). That is because the input for your DC drive motor, connected to the large 1000cm circumference pulley, only needs to be a single spark of current. That is because you only need to rotate this large pulley once, and it will give you a return of 1000cm of moving belt.
Then, when you run this 1000cm of moving belt through one to ten mini-pulleys, having only one centimetre circumference, this will translate into 1000 to 10 000 cycles of AC electricity. There is no more discussion needed, with only one spark of DC input, you are using the mechanical abilities of pulleys, to gain a return of 1000 to 10 000 units, (sparks) of AC electricity. This shows a clear multiplication of electricity, which means that you do not have to pay for it to be generated by fossil fuels, or the heat off nuclear fission. In essence, you are using this technology to multiply already generated electricity, there by gaining free energy.
What is that, now, SEVEN threads all spammed with the same mistake?
Why are you doing this? Are you off your meds again?
