I have a proven model I built. I am looking for like minded people who know more
Started by MeGaFaRR, February 17, 2016, 11:52:50 AM
Dog-One
Quote from: Temporal Visitor on February 25, 2016, 07:39:24 AM
Hello again D-O,
I ask: Wanna learn about doing far better using a one piece part? : a Lever of the Fourth Class.
http://www.backgauges.com/Gen-E-Sys%20II/contact.html
Thank you for the invitation Michael.  I will probably be making contact sometime in the foreseeable future.  Have a few rough edges to polish off first.
Temporal Visitor
Quote from: Dog-One on February 25, 2016, 09:58:02 AM
You are most welcome to do so.
MeGaFaRR
Quote from: sm0ky2 on February 25, 2016, 05:30:29 AM
the first thing to consider is the ratio of gearing.
whether it be belt drive pulley diameter to diameter
or chain pulley diameter to diameter
gear tooth per rotation, etc.
once determining the ratio of rotation compared to the drive mechanism,
one can then determine the torque ratio available, from the prime motive force to the moved object.
from this perspective, one can determine how much energy is transferred from one wheel to the next.
this does not account for friction at the pulley bearings/bushings, or friction on the chain or gear teeth, etc.
when you state that you can "clutch to another sized gear without barely losing momentum in first flywheel"
how much momentum is actually lost? this is important, because it relates directly to the "energy" available from one flywheel to the next.
Thanks for the reply sm0key2:
You are probably the first one ever to respond to any question I have put forward. I really appreciate it. Now as I have stated in my paper all flywheels and ratios are connected with (1:1 pulleys and belts when using centrifugal clutches and sprockets and chains if clutch not required). I am not ever looking for excact answers as I realize there are way too many variables in any situation put forward.
My questions are meant to be general in nature so as to get a general answer, if I did say as you quote up above that I said "gear" as opposed to "flywheel", I apologize for that, I am always trying to transfer energy from one flywheel to the next. The diameters of sprockets or pulleys are of little concern if ratio 1:1.
Here2njoy
Frank,
So glad you reached out to Michael and that you are looking for like minded people that might know just a little more.  I see in your comparison to a car transmission that you are heading on the right track.  Michael's work uses transmission like qualities & setups in the most interesting of ways.  I actually visited him several months back and he has quite a progression of devices over the many years that told me he has learned a very very lot along the way and continues to perfect his designs.  I look forward to your videos and the progression you will make as things "come to mind" and the acceptance of ideas that came before you (as you come to understand them).  I call them "AH HA" moments. Keep up the good work.
MeGaFaRR
Quote from: Here2njoy on February 25, 2016, 03:52:52 PM
Frank,
Thank you very much for that connection, as Michael and I have spoken to each other on numerous occasions and have a lot more in common than just flywheels. This is the main reason why I started that thread just to start the conversation with like-minded people. To see how passionate people are about their knowledge and how guarded they can be. If nothing else, no matter how you get to any conversation and what you get out of it will always be what really amuses me. I love the fact that some will always be helpful, some who say nothing, some, who are there to learn, some to teach, some friendly, some not so much, but almost all will have a very deverse opinion of what is being discussed and all will take away different views of what was said.
I really appreciate all the opinions that have been posted, naysayers as well, as they are the usually the most humorous, sarcastic and enjoyable especially after I had requested that they not bother posting them. Please do continue the conversation on my behalf as I will be pursuing other problems in this wonderful world of ours that maybe "I can solve and save the world".
I bid you ADIEU
Frank
