100W Wireless and Single-Wire Power Transmission
Started by spg, March 23, 2016, 10:20:03 AM
the_big_m_in_ok
Quote from: the_big_m_in_ok on June 21, 2016, 09:21:15 PM
       Hey Spigel,
Try this as an example of OU ideas as a large presentation from the 'Web...
https://www.google.com/search?q=gbluer+exciter&rlz=1C1ASUM_enUS603US603&espv=2&biw=1247&bih=983&source=lnms&tbm=isch&sa=X&ei=6DGOVOynM8S5ogTMw4HYCw&ved=0CAYQ_AUoAQ&dpr=0.9
The gbluer exciter is something I favor very much as having potentially big gains in power output.
--Lee
As an example of what I'm saying, if you 'click' on the 'Web address above, and in the 3rd row from the top, right in the middle of the row, you'll see a center PVC tube with 3 more such such tubes having enamel copper-colored magnet wire wrapped around them.
       What I'm implying is that any number of such tubes can be placed in close proximity to each other, and thusly, generate as much power as you want.   Mere experimentation on your part should give you the particular parameters of your system, as you have it set up.
--Lee
NickZ
   As far as I've seen, each added coil, or bulb increases the load, as well as the consuption, or at least it will spread the same amount of the Exciter's output throughout the varying loads. In any case, the Slayer Exciter is not a self runner, nor free energy.  Nor has any other device that runs on just a simple Kacher/Exciter circuit been known to self run.
   Except for this one:
   https://www.youtube.com/watch?v=zrvAvp_dmlU
   We are looking for free energy, not just economical energy that needs a man made input source.
   Still, an Exciter circuit running off of a small and cheap solar panel/battery set up can provide some use-able light. Almost for free.
allcanadian
@NickZ
QuoteWe are looking for free energy, not just economical energy that needs a man made input source.
I think it's important to clarify this point, all energy is inherently free and there is no such thing as a man made source. Most all the energy we know comes from a nearby star we call the Sun and we did not make the Sun. Wind, Solar, Hydro, fossil fuels, EM energy, life etc...are simply different manifestations of energy from the Sun and we didn't make or create any of this energy either.
Think about that, all energy is inherently free and man has never created nor destroyed or consumed any energy we have only transformed energy which was already present. Thus it should be obvious we are swimming in a sea of free energy and it is simply a matter of transforming it into a form which is economical and useful.
For instance if the new generation solar cells and super capacitors were 95% efficient and the generation/storage price point was only $0.05/watt then no "free energy device" could compete even if it did work. So if we had a $10,000 free energy device which generates 10 Kw 24/7 it doesn't matter because solar would still be much cheaper at $0.05/watt and do the same job because the energy could be stored. In effect a supposed free energy device is no different than a full spectrum solar panel which would work 24/7 extracting EM energy and one could not tell them apart because in fact they are the same thing.
So what is free energy?, what is a free energy device?... it's simply a better more economical way of doing things versus the absurdity we see today. There is no magic only understanding and application.
AC
allcanadian
Nick think of a solar cell like this, when light (photons) hit a free electron they get all excited and the P-N junction layer in a solar cell is like an electron filter. It's just like a big flat diode which holds the excited electrons which jumped the P-N junction on the negative side(-) which leaves a lack of electrons on the positive side(+). So really a solar cell is just a glorified electron pump which is very easy to understand. Now imagine that the "Energy" which excited the free electrons which caused them to jump across the P-N junction (a diode) creating a potential difference or voltage did not only come from light/photons. You see it does not matter how or why the free electrons got excited and jumped the P-N junction... only that they do.
That is the fundamental premise of your mysterious and quite magical free energy device, excite some free electrons from any external energy source and hold the negative and positive charges apart with a diode and store them in a capacitor or battery if you like. The problem here is not science or technology but the psychology of denial and somehow people have got it in their head that all that inherently free energy all around us in all it's various forms does not exist. Obviously they must be a little woo woo because even a blind man knows better. It's like floating in the middle of the ocean and saying we don't buy into that water BS, can't believe it, makes no sense and anyone who believes in water must be a little crazy. Woo woo indeed.
AC
NickZ
  We may be surrounded by ambient energy. But,  hydro, solar, wind, and other current "free energy" sources, are anything but free.
  A solar system to be able to turn on my electric hot water heater (5000w) on, to take a hot shower would cost thousands of dollars.
  My current grid costs per month is $25. As a comparison. I would be dead, before a solar system would be paid off.
  You're also forgetting that batteries will need replacing in a few years, and are going up in price, not down. And the price of  the controllers, wiring, is also going up, not to mentioned installation cost. The solar panels themselves are still at best about a buck a watt, or higher.  Not anything like the price you stated, by a long shot.  Therefore, solar is still a big rip off, and has not really become economical, for most people today. And some of us, like myself, don't have enough sun light, wind, or a constant water source to draw on, for hydro, wind turbins, etz...
   Building a self running device, oneself can be very cheap, sometimes even free.
   I figure the cost of this one, below,  Is less than $100 to DIY.  4000w output.  Of course, IF it's true.
