Mechanical Resonance (Projects)
Started by Magluvin, March 25, 2016, 08:01:12 PM
tinman
@armcortex
Your insulting comment has been removed.
Please stick to positive input on this thread.
Brad
Magluvin
Thanks Brad. The guy is just a troll. Seen him just doing he same on other threads.
Mags
tinman
Quote from: Magluvin on April 14, 2016, 11:44:34 PM
Ok, lol, OK, I see I start my videos that way. OK!
https://www.youtube.com/watch?v=5Fmmg9UXnw4&feature=youtu.be
Mags
Thats a whole lot of magnetic field you have swinging away there mag's.
Would love to see what kind of output you could get from some secondaries wound around those two speaker coils. I bet the difference between the oscillator being in play and not,would be huge.
Brad
massive
Hi Tinman
model T coils are good to play with . the box is full of tar or pitch and needs to be heated to remove it in order to get to the capacitor for repairs , original is a paper cap.
you should be able to get one some where to play around with.
I hook mine up with the pri + sec disconnected = HV AC .
green cap across the reed on pri
the far right coil is tin can type coil , possibly Lucas cant remember , Ive done heaps of coils for HV experiments
Magluvin
Quote from: tinman on April 15, 2016, 10:24:51 AM
Brad
Ill do that tonight.  Was thinking on a bracket to hold a magnet with pole facing the back wall, and maybe build a front wall to, plexi, and put mags and coils on both sides doing the same. This way we can have the coils pole faces dragging higher density fields across the windings for better efficiency. Maybe some core for the coils, and maybe a stack of mags from back wall to front wall to not waste the field of the mags backside if it were just 2 separate magnets.
Also making a shorter spring strip for higher freq to try.
Be back later
Mags
