Any ACTUAL OU devices on this whole forum
Started by Permanente, May 17, 2016, 08:10:37 PM
Permanente
Thanks for the replies guys!!
I think you guys are on to something with the politics of energy and etc... Everything always comes down to a business model and the "HAVES" imposing their rules on the "HAVENOTS."
If you want to break into their world you probably would have to play by their rules. I for myself know alot of people that are perfectly fine with skirting the line or avoiding the empirical structure all together.
you know beatniks at heart.
I figure with enough energy you can literally take care of almost all other necessities. Dehumidifier for water (with filtration system), ac and heater for temp control, light for seeing and tv/entertainmentl, and of course to power up tools and equipment to make your life easier
So a magical powerbox would make everything simpler for me.
So basically in the real world the main issue is everyone is a slave to the power grid even if they dont know it. And if that were to collapse or go offline for X reasons chaos ensues.
Online on the other hand the things i am seeing is a bunch of clickbait, outright scams, and an overall unhealthy environment when it comes to energy discussions.
I dont believe it is too difficult of a contraption (magicbox) i just really am not well versed in a lot of physics principles.
It does not have to be necessarily overunity (more out than came in).
It does not have to be perpetual motion (the earth wont exist forever anyway)
it does need to produce energy from fuel that is readily available.
Main contenders I think a combination of many or all of these could really work
Gravity + momentum + bouyancy + inertia + magnetism
Somehow someway get a flywheel spinning on its own...
jimbo
Hi if your interested there is a way but It will need some work. I showed this before . go look at the formula for a a string of capacitors in series you will see that the total is equal to the total divided by the number of caps. (All caps being equal in uf's) including the first cap.the charging cap put a positive charge on it and a earth ground on the last cap. And all the calls will generate equal charges.the first cap you will have to charge but the rest charge them selves. By inductance aka free.the more caps the less you have to charge to get the same results.
Pos-----l I------I I------ll------l l --------l l ------(earth ground)
(Applied.    Free. Free  free   free
It's like taking a pitcher of water you would have to work for dividing it up into ten glasses you still have the original water but now you worked for only one glass.power extraction is different in that each cap needs to be discharged individually or you just screw it up .but it refills right away. Also if you measure the caps while they are still in series the voltages will be different because of there interrelated state but the charges are all the same. If you study this out on the internet you will see but you will need to go to the area of physics they don't tell all at any one site but collectively they tell it all. It's been with us like from the beginning and no one sees it. Strange like a mental block or programed avoidance.?   Jim out
jimbo
Hi I just read the others posts and there wrong this system is like nature's way of making lighting Thu electrostatic induction . you see any lighting on a sunny day ? No but thru clouds and water vapor and random charges and proximity with other clouds bang!! Something from nothing and it can kill you!! .those boys are closed system people sure your not going to get any were that way it's a zero sum system.! You have to be in an open system. This really gets something from nothing.same way nature does it by attracting the current Thu a strong positive or negative charge they just come trying to rebalance there environment. It's called regauging. You will never get it done in a closed system that's why they keep you there your a dog chasing your tail. Jim out  ::hell even Tesla said the same thing "connect to wheelworks of the universe " not a closed loop.☑
memoryman
jimbo, I suggest that you learn some elementary electricity.
jimbo
I am a cet and i have second class FCC license yet I need more or is it the other way around.? This area is not studied  from conduction to induction .explain the circuit please .and why I'm wrong. Not just hit and run.
