Any ACTUAL OU devices on this whole forum
Started by Permanente, May 17, 2016, 08:10:37 PM
Permanente
Electrostatic inductance huh . I will be looking into this and see if i can learn some stuff.
Sorry i cant be of much help here but thank you guys very much especially jimbo my man thanks!!
How much juice do you think can be attained through this method? enough for real usable power or just enough for led light bulbs (which is a wonderful start by the way)
And can this be multiplied and scaled up or would the capacitors have to be the size of a truck.
I actually follow a channel on youtube, and I am not trying to advertize but it is very interesting stuff
the guys name is "the teslonian(on youtube)" and I believe I saw him building giant capacitors using pvc piped and aluminum foil.
On a side note if anyone has the resources gravity powered generators would work if scaled up. Like a grandfather clock but you park your car on a gian platform and it slowly drops on levers and springs for couple of hours lets say. then you drive it off reset the platform and start all over again.
This could in principle produce very usable power no?
jimbo
My first attempt used two 60uf 440 volt motor caps and 119volt DC Thu a bridge rectifier running on an inverter and a car battery. And I was fireing off 4 watt 120 volt light bulbs each second if that was for 12 volt batteries it would have been .33333 amps every other second .that's just a first attempt. Don Smith uses caps to an inverter . and runs a lot.
jimbo
You know when your standing in the dark with nothing any power is good .the trouble with people is that dam powers line and water line you hide be hind turn it all off and then make your way.it's like a drug get away from it and you'll see better. Do you see any ou stuff working buyable  .even John. B.  battery swapping stuff runs down . so just go away and make your big contribution of wineing some were else .
jimbo
Sorry permanents dis regard that last post I speed read it and screwed up what you were saying I apologize. For that brain fart. Every thing has to come from some were . can't get something from nothing . this is bs and this proves it. Just look at the very simple arrangement of a charged balloon bring another near but not touching then touch it to a ground   now you have two charges double the protons or electrons and you haven't touched or taken any thing from the first you can do this all day and night 24/7/365 making something from nothing. But here you use large caps they work very well it's just automating the switching that's a problem. To be worked on.and these charges can weld steel or kill.and running all day and night you'll have a shit load of electricity. You see this attracts energy were as every thing we use we have to work at and pay for but not this way ! It just comes running you couldn't stop it if you wanted to!.
Gothic
Quote from: jimbo on August 02, 2016, 02:37:52 AM
Thanks for sharing, it is appreciated. A word of caution "Don,t follow a leader" use your own intuition, it will serve you better.  ;)
