Marko Rodin Coil -- 007 Device
Started by Dog-One, June 02, 2016, 12:26:11 AM
sm0ky2
Rodin-coil as a 'super antenna':
Not necessarily "flat" to You where you stand,
but there is a plane of communication around you,
upon which a maximum of signals from various directions reaches you.
And when the coil is 'flat' to this
You have 2 loops facing in every direction.
With 1 coil open, the other across a resistor,
you can pick up every signal
I'm sure you could crystal-radio that as a power source
But thats way too much work for nothing
However, as a receiver linked to an amplifier and filters
This probably blows your 1/4-wave tree out of the water
Jimboot
I use them for xmas decorations these days. :)
kolbacict
I didn't succeed.
This coil showed no difference from a conventional inductor.
No miracles.
nix85
Nothing to do with Rodin coil but i'm gonna report here a strange thing that happened
few hours ago. I got a 500W 12V/24V battery charger, it's quite bulky, transfomer type,
at 24V it outputs 30V pulsed DC full rectified sine, no caps. I keep it on the floor and next
to it is this chunk of cement brick. Today i turned it on and after maybe few seconds
the charger which is say about 18.5cm x 9cm x 18cm and weighs about 3kg i'd say,
rocked backward away from the brick, as if someone kicked it with a leg, almost tipped
over. No explanation whatsoever, some kind of gravitational effect.
It reminded me of this video showing coil repel a rock.
https://www.youtube.com/watch?v=muJqtz-ECfg
sm0ky2
Rocks, cements, clays can all have ferrous content.
while not always 'magnetic' to say a permanent magnet,
electrical fields can cause magnetic induction, polarized opposite the field.
controlling this requires multiple fields overlaid
(electromagnetic levitation, the hitchinson effect, quantum 'traps', tokomok, etc)
Back to the rodin, studying the magnetic fields
[1:1 transformer configuration]
The magnetic field does indeed condense to a vortex in the center.
You can spin a ball in a cup
However it reaches out to a great distance at its' extremities. Possibly 100 larger than the coil.
weak at these distances as well.
but almost nonexistent at the induction points at the wire surface.
This means that induction is governed almost entirely in the electric vector.
[edit: i forgot to mention the reason i point this out^^^]
These devices should work better with very thin guage wire
My first one is inherently too thick of wire.
I'm going to step it down and run more tests.
