-----> Why do O/U Devices Only work for certain people, & NOT others.
Started by FatBird, June 21, 2016, 04:28:05 PM
FatBird
https://search.yahoo.com/search;_ylc=X3oDMTFiaHBhMnJmBF9TAzIwMjM1MzgwNzUEaXRjAzEEc2VjA3NyY2hfcWEEc2xrA3NyY2hhc3Q-?p=dan+davidson+shape+power&fr=yfp-t-s&fp=1&toggle=1&cop=mss&ei=UTF-8
Dan A. Davidson:
Ok guys, Jerry asked me to tell you about motor sensitives. Here is my definition of a "motor sensitive".
1. the "motor" monicker is from the use of the word in describing the nervous system.
2. a motor sensitive has certain special abilities:
    a. Can sense electric and other fields
    b. Can manipulate these fields (either consciously or unconsciously)
    c. Can use this special sensing to "tune" devices which will exhibit unusual effects like levitation,
       free energy, etc. This can be unconsciousness or conscious on the motor sensitives part.
3. The term was invented by my old friend Larry Wilson who was a motor sensitive but
    could also use his talents to duplicate devices and make them work.
John W. Keely was a motor sensitive. Equipment would work for him and no other. It is possible
that other free energy inventors and stage people were also motor sensitives.
For example. We have some really good explanations for some of the free energy devices but
none of them have worked.
I could expand this list but you should get the idea.
Dan A. Davidson
______________________________________
Do a search on:  Aether Motor, Tilley's Spinner Box.
Imagine an electric machine having no electrical input itself and which, when started on no
load by a drive motor and brought up to speed (3250 rpm), thereafter runs steadily at that speed
with the motor drawing a little extra input power with a time delay rate of about two minutes.
The machine rotor has a mass of 800 gm and at that speed its kinetic energy together with that of
the drive motor is no more than 15 joules, contrasting with the excess energy of 300 joules needed
to satisfy the anomalous power surge [to spin up from rest].
Imagine further that when the motor, after running five minutes or more, is switched off and the machine
is stopped, you can restart it in the same or opposite direction and find that it now has a memory
in the sense that it will not now ask for that 300 joules of excess input. 30 joules will suffice provided
that the time lapse between starting and restarting is no more than a minute or so.
This is not a transient heating phenomenon. At all times the bearing housings feel cool and any
heating in the drive motor would imply an increase of resistance and a build-up of power to a
higher steady state condition.
The experimental evidence is that there is something spinning of an ethereal nature co-extensive
with the machine rotor. That 'something' has an effective mass density 20 times that of the rotor, but
it is something that can spin independently and takes several minutes to decay, whereas the motor
comes to rest in a few seconds.
Two machines of different rotor size and composition reveal the phenomenon and tests indicate
variations with time of day and compass orientation of the spin axis. One machine, the one
incorporating weaker magnets, showed evidence of gaining strength magnetically, as the tests were
repeated over several days.
Remember Floyd Sweet also said that the Output Voltage of his devices varied with the time of day!!
conradelektro
Quote from: FatBird on June 21, 2016, 04:28:05 PM
May be that is similar to the Aspden Effect http://www.haroldaspden.com/lectures/30.htm
I did some tests some time ago and could not find anything surprising. But one may always claim, that I did something wrong.
Remember, one can never prove that sometning does not work. (One could only provide positive proof, namely that it works.)
Greetings, Conrad
FatBird
Dan Davidson's PDF Book can be downloaded Free.
http://www.free-energy-info.com/Davidson.pdf
_______________________________________________________________________________
SAMPLE from his Book introduction:
In addition to physical instrumentation, I have also used clairvoyants as human instruments when I have been able
to prove conclusively that they have their inner sight open. A true clairvoyant is able to see the energy fields of the
aetheric plane such as the light around a person (i.e., the aura), around various activities of light in nature (e.g., around
and inside trees and living organisms), around geometrical shapes, around magnets, can see into matter, has both
microscopic and telescopic vision and many other remarkable abilities. They can see the flow direction of subtle energy
fields, its color, and general shape
. My experience in psychic research and psychological testing enabled me to identify
some first rate clairvoyants who have provided additional, very valuable, insight into the science of -
conradelektro
Quote from: FatBird on June 22, 2016, 09:44:30 AM
Well, the stars of the esoteric industry are so very verbose, millions of words, endless theories and grand promises. But where are the machines working according to these ravings? Big in the virtual, non existent in the real world.
A book is no proof!
Greetings, Conrad
Cherryman
A lot of great thinkers and inventors stated that it would take besides the "hardware" also a kind of believe and acknowledgement of the "creator" *
* Where creator not should be confused with "God's"
