Thanks to ALL for your help!!
use pulleys to multiply total # of rotations = AC electricity
Started by that_prophet, July 02, 2016, 11:35:19 AM
Quote from: citfta on October 02, 2016, 07:36:19 PM
You have absolutely no proof that any of this statement is true.  Anyone that has actually worked with AC generators knows that you are TOTALLY wrong with your ridiculous theory.  As soon as you try to do anything with that great voltage you think you are going to get then there WILL be torque.  That is one of God's basic laws and to deny that is to believe the lies that satan's spirits are telling you.
Pardon,cifta,to correct you,but you are mixing different languages !
wikipedia german https://de.wikipedia.org/wiki/Satan
google translation english https://translate.google.com/translate?sl=de&tl=en&js=y&prev=_t&hl=de&ie=UTF-8&u=https%3A%2F%2Fde.wikipedia.org%2Fwiki%2FSatan&edit-text=
So you can see and listen that the counterpart from satan/Satan is not God
                                          but JHWE,original lingual counterpart !
And going back to the religion original:
Theology is also a science and has to be treated by same patience and integrity like physics !
Paul-R
Quote from: lancaIV on October 03, 2016, 01:04:15 PM
                                          but JHWE,original !
I'm sure you are both right but not as sure as I am that that_phophet is as nutty as a very nutty nutbag.
Maybe nuttier.
also a nutty nutbag can become filled positively ! Under common sense conditioning ,the "positive" !
that_prophet
This Free Energy GEM technology works on simple pulley mechanics. http://free-energy.yolasite.com/  This is the way it seemingly gets around the laws of thermodynamics, being able to get more electricity output than you put in. It does this by only having to input one spark of DC electricity, to rotate a large 100cm circumference pulley the once. This gives you 100cm of moving belt, which you then run through 1 to 10 mini-pulleys of 1cm circumferences, with AC generators attached, giving you between 100 + 1000 units of AC electricity.
(these 1000 units of AC electricity are running free, merely winding up massive voltage, and since you only get torque resistance from producing power, which is P=IV, and the only current we need to produce is one spark=(practically nothing), massive voltage times practically nothing, still equals practically nothing, as in no power = no torque)
YES, THAT'S ONE SPARK OF DC INPUT, GIVING YOU AN OUTPUT OF 1000 CYCLES OF AC
(Now, how can you tell me that with 1000 units of AC electricity, that you would not be able to produce that single spark of DC current, that is needed for your DC drive motor)
PULLEY MECHANICS HELPS YOU SEEMINGLY DEFEAT THE LAWS OF THERMODYNAMICS
Allowing you to pull more AC electricity out of this mechanism, than you have to put into the system
Nob,thats_prophet !
defeat: no
seems:yes
                                            Laws + order+conditioning !
https://translate.google.com/translate?sl=de&tl=en&js=y&prev=_t&hl=de&ie=UTF-8&u=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3Ddf9vxcbjX3I&edit-text=
                                            Zugarbeit versus Hubarbeit ? Newton ?
                Rotor/Stator : fix or flexible,dry or "wet" surface ? Reibungskoeffizient,Reibungszahl
                                           "no/ultra low friction : target no resistance"
