Dual energy generation with magnetic seesaw system and gravity
Started by vikram_gupta11, August 15, 2016, 06:12:34 AM
vikram_gupta11
Sir,
I will present an another sketch before this forum based on this seesaw principle after some correction within two days and to know the reviews and comments.
Low-Q
OK. I apologize if you feel I've been bantering. I just want to tell you my honest opinions and experience - and I tend to speak without filters...there is no bad intentions.
Please go ahead with a new design.
I do allways think it's exciting to analyze any given issue. I even make problems for myself - intentionally!, just to try to solve those problems, and learn from my intentional mistakes.... I make things that I do know won't work, just to figure out why it doesn't work. I have a project going on now. The device I'm making are beyond my knowledge, because I have no clue why it does not work as I have designed it to do. The only clue I got is the decided trouth that over unity isn't possible. You know what? I don't give a sh**t in textbooks ;D
My own project is about 30% done. The design does not violate any law - as far as I can understand, but still I do not know why it wont work.. When it's done, I will post the results here. If I got time, I will finish the project during this weekend, or next week.
Good luck with the alternative design!
Vidar
vikram_gupta11
Dear Vidar sir,
My earnest request to you that could you please build a working model of  my second concept "perpetual energy wheel' as you said that you have a metal wheel and can build it in a day .
Please do me a favour and try to build a working model of this 'perpetual energy wheel'.
I shall be very grateful to you .
vikram
vikram_gupta11
This Idea is based on Magnetic Repulsion and Kinetic force.
According to diagram there will be a  Wheel and a magnet(1) will be attached with this wheel. There will be a balance system(seesaw system) and two magnets(2no.magnet and 3no. magnet) will be attached with this balance system .
when 1 magnet will repel 2 no.magnet then the 2 no.magnet will move upward and due to this movement the 3 no. magnet will come down and will work to repel 1 no. magnet and wheel will start to rotate.
when 1 no. magnet will again repel 2 no.magnet after a rotation then the 3 no. magnet will again work to repel the 1 no.magnet.
THE weight of magnets of balance system will be equal.
In this way the wheel will rotate again and again.The magnetic strength of 1 no. magnet will be high than 2 no. and magnetic strength of 3 no. magnet will be high than 1 no. magnet. The weight of 2 no. magnet and 3 no. magnet will be equal.
We will fix this all system in horizontal direction and metal wheel must not  made with IRON or Steel metal instead Brass or copper or Aluminium.
Please build it if you have sources .
I shall be very grateful to you.
vikram
Low-Q
Quote from: vikram_gupta11 on September 17, 2016, 02:41:37 AM
Dear Vidar sir,
vikram
Yes, I have a steel wheel which works great as a flywheel.
It is the same wheel as you see in the video in the link below,
where I demonstrate an imbalanced wheel in a pendulum configuration.
It was a discussion going on a while ago if the vibrations on the pendulum arm
would create energy without affecting the spinning flywheel.
However, as you can see in the video, as soon as I take energy out of the vibrating pendulum,
the wheel slows down rapidly.
The explanation is, when I load that pendulum, the viberation of the pendulums viberation will be a litle delayed.
So the energy that is transferred to my hand will try to force the flywheel to stop.
https://youtu.be/vV3RAL-SWjc
Your concept in your drawing will make the flywheel spin relatively free if there is little loss in the spring.
If you fill that spring with whool or cotton, or a generator, you will have a shock absorber,
and the vibrations in the spring will transfer energy into the whool or generator.
This will cause the similar delay in vibration, and the flywheel will stop sooner - just as the pendulum.
But your design is so easy to build, so I will build it and you'll see what I mean.
I have a question:
If both magnets are attached to the same seesaw, and the spring affect both magnets equally,
how do you determine which way the flywheel will rotate?
Vidar
