Dual energy generation with magnetic seesaw system and gravity
Started by vikram_gupta11, August 15, 2016, 06:12:34 AM
vikram_gupta11
Dear Vidar Sir,
The spring will work to  just hold the seesaw system and we can take a tubular piston instead of this spring .This wheel will will move in clockwise direction  and we will have to fix the whole system in horizontal direction.  The clockwise movement of this wheel will be determined by 3 no. magnet as it will push the 1 no. magnet in clockwise direction.
If you have any doubts then please tell me to clear your doubts.
Thank you Sir.
Vikram
Low-Q
Quote from: vikram_gupta11 on September 19, 2016, 01:31:54 PM
Dear Vidar Sir,
Thank you Sir.
Vikram
In your drawing there appears to be two magnets attached to the wheel. Magnet 1 that appears to attached some distance away from the wheel (via rod), and a magnet at the bottom that is attached directly to the wheel. Is the bottom red "lump" on the wheel also a magnet?
Vidar
vikram_gupta11
No it is not a magnet  it is just a weight to balance the wheel.
vikram_gupta11
this wheel will move definitely and this device is a game of exact timing  if we get  exact timing among these magnets then no resistance can stop this wheel wheather it is air resistance ,vibration or heat or anyother.It will move........
Low-Q
Quote from: vikram_gupta11 on September 22, 2016, 12:41:03 AM
Sorry for being late. I have pundled with other projects lately, but I am now ready to build your device.
There is no established or correct ways to make the timing for an OU device, because OU has allways been out of the question in physics.
So this timing is something that must be invented first. If you got a solid theory of correct timing for an OU device, it will save me lots of time in trial and error.
Can you please provide your math that convince you that wheel will provide excess energy?
Vidar
