TD replications
Floor
@ All reader
If one linked two Twist Drive units (SL to SL) 180 out of, and flattened their in and out curves
(if the force curves are not flattened, the peaks are out of synchronization) then ...
one would have essentially the same thing as two equal weights, each weight hanging upon the opposite side of a pulley.  No OU there.
Similar results would be had in linking two TD units one RO as output the other RO as input (180 out).  No OU there either.
The TD is perhaps half of an equation for net gain in work from magnets.   Two out of 4 interactions, needed.
   floor
Thaelin
Hi Floor:
   That has been the catch in the use of magnets. They play a roll in many things today. But when you try and use them to make an all magnet motor, it always seems to be a sticky spot or you wind up with a null effect. But I still love to play with them. One day, one of us will hit the mark. And then we will ride.
thay
Helo floor,japanese inventor Kango Iida his hydraulic converter US4464095,original based for two ccw/cw wind/water force paddles
Instead wind/water now permant magnet converter as ccw and cw orientation forces source ?
FEMM-simulation study ?
With my best regard
OCWL
p.s.: probably some will find "hidden options" in use from ccw DC motor and cw DC motor and/or ccw AC motor and cw AC motor couple
Floor
@ lankaIV
"Helo floor,japanese inventor Kango Iida his hydraulic converter US4464095,original based for two ccw/cw wind/water force paddles
FEMM-simulation study ?"
                         thanks
I've been reviewing some old materials here.
I am heading back into the the magnetic shielding stuff.
          @       https://overunity.com/16954/magnets-motion-and-measurement/
and then checking out CITFTA new topic @ https://overunity.com/18506/possible-magnet-motor-research-ideas/
I'll come back to the Twist Drive some times in the future, I'm sure.  I don't have a hope of it,    in itself    developing into an OU device, but it sure     has been / is   a good study / learning device.
     floor
Floor
Thanks Thaelin.
     floor
