TinMan's "Over Faraday HV HHO production"
Started by ramset, November 20, 2016, 04:28:24 AM
ramset
I see the Tinman has started a tutorial On a process to Break The Faraday Limit,
"Gas Production way over what was once thought possible "
Part 1. of the introduction here
https://www.youtube.com/watch?v=p8e7dOVzyTM
All comments welcome.
respectfully
Chet K
Thanks Grandma
tinman
Here is video two in the series of video's to come,regarding this project.
Faraday's limit is an MMW of 9.28
We intend on breaking this limit by 230%+
Faraday's limit was set using low voltage-high direct current.
We will be using high voltage-low pulsed current,with a coil shorting circuit to obtain resonance between the cell and source(inductors primary).
This second video is of the cell reassembled after a good clean.
The first and second video provide all information about the cells design,and how all current leakage points where insulated as much as possible.
I am starting at the beginning,so as all interested in replicating,have all the required information.
https://www.youtube.com/watch?v=zRpG0q3TLHk
Brad
tinman
Pt 3 is the cell up and running.
We first set some bench marks for the cell,and find out what type of efficiency the cell has on both straight and pulsed DC.
I am still to make the displacement measuring part of the DUT,and so,in this video we are using a recalibrated o2 flow meter.The pill in the flow meter has been changed to suit HHO gas flow.
https://www.youtube.com/watch?v=KABL2LRP08w
Brad
markdansie
Hi Brad
I wish you all the best with this
I covered it at Revolution Green
http://revolution-green.com/faraday-hv-hho-production/
Kind Regards
Mark
i_ron
Quote from: tinman on November 20, 2016, 05:53:36 AM
Brad
Looks interesting Brad, mind if I join you? I promise to do everything differently, LOL
Here is the start of my cell, never made one before and so would do it differently for the next one.
Drilling the holes: Stainless is tough stuff to drill and will raise quite a bur if you let it. The trick is to sneak up on the finished size with at least two pilot drills, then it is an easy debur of each side of each plate for each drilled hole.
Ron
