The Concentric Capacitor - Key to the Kapanadze Device and similar FE Concepts?
Started by Zeitmaschine, December 16, 2016, 04:40:24 AM
Zeitmaschine
The concentric wound primary and secondary coils of a transformer have capacity already. The third plate is the core. See the Stepanov transformers working without oil.
The link to the Testatika video is on post one. I simply watched it very closely.
jbignes5
Quote from: Zeitmaschine on December 19, 2016, 05:45:34 PM
To have undamped oscillator you can't have a core. Hence the ground/virtural ground going in the middle of the transformer in the design I showed..
I have a hard time believing videos sometimes. anyone could make it and anything can be done. But in TK's video the proof was the Tesla information. It fit and it worked. This one system was doing all of the videos TK was releasing. All from the 1892 lecture.
In the beginning it took Tesla a while before he figured things out. He didn't start knowing about the plasma thing. But after he figured it out he even boasted about a dynamic theory of gravity based on it. For which he never got to release it and died. Papers were confiscated and still no papers on such things to date.
Also the wiki that you posted the Testastika has the exact reference to the diagram I posted. In fact all the information about it on the wiki page is based off of the same guys doing the diagram.
Lets look at a Tesla improvement to the capacitor: https://teslauniverse.com/nikola-tesla/patents/us-patent-464667-electrical-condenser
and here :       https://teslauniverse.com/nikola-tesla/patents/us-patent-567818-electrical-condenser
Coincidentally it is remarked in that patent about oils in the use of condensers... The second one tells a better explanation.
shylo
The biggest problem, We only look at half of what's going on.
Everybody loves the positive, but try to eliminate the negative.
The potential difference is what, we need to use, need to see.
artv
jbignes5
Quote from: shylo on December 19, 2016, 06:31:31 PM
artv
Yeah I agree...
Actually the potential difference is the drive or direction setter. The movement of what, is what we need to see. What is the potential difference moving. That my friends is the Aether or plasma as I call it. Learn to attract it and it can multiply your movement or give it more umph. It is an inertia multiplier and we can convert it to any form of energy in that process.
This is actually what keyed me on what the Tower was actually doing. He spread the very high voltage across the dome of single terminal bulbs and drew the plasma down from the ionosphere in a great ball above that surface. Then he let it short to the ground via the central shaft after the dome discharged. There was a capacitor shorted solenoid around the base and acted like a choke that he would disruptively discharge to the ground through a bifilar coil. A solenoid around that coil could harvest the huge currents generated by that tower. In fact I believe this is what shorted out the generators at the utility place on the island. He had to fix that one lol.
In essence the Tower was nothing but a blocking oscillator sucking down plasma from the ionosphere and shorting it to the ground where you could tap the flow at the ground connection via induction.
These smaller versions need higher potentials and to make it safer you should use oil on the coils and caps. Heating goes down and efficiency goes way up to.
I also don't know how to say it by there needs to be a spark gap. It needs to have the plasma to attract the bulk of plasma into this smaller system. The ground wire inside of the transformer is for some of the plasma to go to ground and some can be scooped out via induction to any load you need.
In Tk's back yard video he used a heavy copper coil to discharge into and the extreme high voltage impulses attracted the plasma to the awaiting ground wire. The coil in the middle was most likely a coil designed to resonate at 50 hz to match their system there so he could use the normal loads. Although I don't rmember anything being used except light bulbs on that one.
To me it looks like a huge virtual transistor with inductive output, meaning not directly connected to the main flow. A certain flow of plasma would be capable of a certain output as well. Meaning the bigger it is the more current it can push in the load circuit.
Now there are great flows of plasma going to ground already. What do you think hurricanes and tornadoes are? This might actually make things nicer around us. We would release the pressure causing the great flows of plasma to the ground now. Just think about the energy of a tornado and explain where it comes from? If you knew about plasma and density of plasma layers around our planet then you might figure it out very quickly how this could take energy out of that systems and put it into our man made systems. Tesla found his new Niagara Falls except this one was bigger... Way bigger... Limitless energy... Clean... Natural.. And very powerful... AND TO BOOT completely FREE. Well except for material costs of the systems. After that it was essentially free.
Zeitmaschine
This is why I stuck to TK because he admitted where he got the information from.
And that's the mistake, sticking to TK. I prefer to see the overall picture, so I can combine different trivial elements to a comprehensive view.
That big Kapanadze copper coil is completely fake. I figured that out in mid 2012 already while doing some experiments. In that green box video Kapanadze himself admits (made a slip) that the »resonator« (as he calls it) is INSIDE the box. So the coil looks nice but does nothing. My best guess here is that the tin can (the resonator) is now inside the box working still as concentric (resonating) capacitor.
One more discussion cycle completed.
Show me one single video or image on the whole internet presenting an electric FE device, real or fake whatsoever,  in which I can see one single drop of oil anywhere, or an inventor stating that his electric device needs oil to work. Old tube TV's working with up to 30KV high voltage and nowhere in those TV's can we see the slightest sign of oil in the flyback or other parts. So what level of high voltage (in oil) do we need to get energy? 100.000 volts? 1.000.000 volts?
This free-energy-from-oil theory leads to nothing except going in circles over and over again. So I will end this discussion right here.
