The Concentric Capacitor - Key to the Kapanadze Device and similar FE Concepts?
Started by Zeitmaschine, December 16, 2016, 04:40:24 AM
jbignes5
Lets look at this in detail:
The feeding mechanism is left out but it includes other discoveries by Tesla. Like the disruptive discharge circuit which in this case would go to the left of the transformer. Some other discoveries like making the primary a bifilar coil also are nopt included in this.
If we look at the sequence below we can see how this operates in this section of the device. Adding appropriate virtual grounds like the body of a car and antenna is another addition that can be used. In tk's version he used two ground points like Tesla instructed at figure 4 bottom right.
If we understand that the Earth has a capacity then we see how each point in that diagram depicts access to a capacitance and how to simulate it via the bifilar methods by replacing the capacitance with an open ended bifilar coil..
In the case of adding a ground to the center of the transformer core, well it makes sense because the amount of current you can increase by the capacitance of the earth makes the secondary have increased access to current from the ground. This is a charge pump in essence that uses great capacity to move energy out from the earth into our system and then allow it to refill from the atmosphere naturally. Like pumping oil from the ground so to speak. In this case we want an AC component to eventually flow out of this system so current must go both ways into and out of the ground.
So, what if we replace the capacitances on each end with the capacitances of the bifilar coils and connect each free terminal to a virtual ground like the antenna and body of a car? Wouldn't the current flow anyways like both ends were connected ? Wouldn't that flow also draw in more plasma and raise the density between the free ends of the extra coils.
Zeitmaschine
The gap when discharging is full of plasma and that plasma is highly conductive. It can draw in energy trough that gap rhythmically. Timing the system to open the lock and then allow it to suck in energy is the way to go here.
A spark gap is a fast switch and at the same time a low-ohm load because it dissipates light, heat, sound and radio waves. Therefore it can draw energy from the Aether in two ways: a) it shorts the capacitor consisting of the two spark gap electrodes (self-shorting) so the warped Aether between the electrodes powers the spark (but we are unable to make much use of that energy), b) it shorts an external capacitor at lightning speed trough a load (see Frolov) so the warped Aether between the plates of that large capacitor can power the load for free.
But this is only true if a common factory-made capacitor is used. When using a concentric capacitor there is no need for a spark gap. Here we can draw the additional energy coming from the Aether by induction with the help of resonant frequencies. That's the theory so far.
What was in the Can was an oil filled transformer with the capacitance built right in.
You could show me the location of the oil filled transformer that powers the Steven Marks TPU. Also the capacitors (cans) of the Testatika are rather unsuitable to be filled with oil. The Hendershot device shows no sign of any oil-filled parts as well.
Therefore I think we should experimenting without oil for the time being.
jbignes5
 Thats because those other inventors tried to do the same thing but in a different way so they could patent them. The real thing is the device TK used and the very device that Tesla has shown us.. In almost all of TK's videos he has a box or can that has the oil submerged capacitor/transformer in.
The back yard video, the in the house showing the investors demonstration and the Turkey display which should have the pedestals as the oil container.
There is a lot of flim flam in those videos to hide the real device but TK chose to hide it like in the aquarium version. Why he did was to get some cash out of it like Stivep reported. In fact I was approached by someone who wanted me to be the middle man in a transaction to getting the legit method but I turned it down. It isn't for sale because Tesla has given it to us for free.
Tesla's version is the best way to get energy via the pumping method. Either in a single terminal or dual terminal mode. Single terminal mode needs the ground so just understand that. The Dual terminal mode should be able to work without the ground via a virtual ground loop.
Let me ask you a question. Do we create plasma or does it exist all around us?
I am of the opinion that Tesla knew it was all around us and it gets attracted to the gap via the stress between the two electrodes or if it is high enough via a one terminal. We don't create energy but we can attract the carrier of it in great densities. Thats what a Spark gap does. It attracts plasma to the gap via the steep voltage differential of the electrodes. It flows to the potentials like water flows down hill, except in a 3d way instead of 2d surface that water flows on. Plasma is not created and it is not a state of matter. It is simply plasma and matter divides and draws energy from the plasma. Plasma is everywhere only in differing densities and environmental potentials.
A coronal discharge is the plasma moving and being energized by the high potential terminal. Even if that terminal has only one terminal. Hence why the beautiful brushes form even on that single terminal. A magnetic field is just such a thing as well. It is plasma attracted and locked into matter in the case of a magnet. The field being locked into the matter as it phase changes. Most likely raised in density, which packs it between the matters atoms and forms the flows outside of that magnet by the increased density of plasma around the magnet as it is formed. Like filling a balloon and tying it off to enjoy the whole day.
https://en.wikipedia.org/wiki/Corona_discharge#/media/File:Plasma_wheel_2_med_DSIR2018.jpg
The plasma is not emitted but attracted to the tips of this wheel. It is then revealed by intensification of the plasma as it approaches the tips via condensing of the density of the plasma. This of course allows the plasma to conduct better and it gets more intense as it heads twords the tips.
So back to the gap. When the plasma condenses and conducts the gap space it can and will draw in energy that was carried by the plasma moving twords the gap as it condenses. Each impulse drawing more energy from the collected plasma of each impulse. Each firing of the gap draws in new plasma and new energy. Thats how come the disruptive discharge circuit works so well. It doesn't rely on the capacity so to speak. It does use it but the energy doesn't come from the Caps. It comes into the system when the spark gap breaks down. Thats where all of the effects you mentioned come from. It's not the cap but the gap that is important. A gap doesn't dissipate anything. It radiates after the discharge ends. That is the plasma going back out into the environment in a broadband emission way, sorta like thw way an E.M.P. works.
Well this is a far as I have gotten so far until I can start my own work on this area.. I'm still working on something else on the bench atm.
Reference for plasma being around a magnet by intensifying the plasma and showing the magnetic structure:   https://www.youtube.com/watch?v=2B-lKgcQJvg
This addendum to my take on this comes from further research into Tesla's experiments. I try to reference to the exact material as I do. Listen I don't know for sure about all of this but I am 85% sure it is correct based on researching Tesla's papers and experiments. TK did nothing more then duplicate the experiments that Tesla was doing. Nothing more and nothing less. Tk tried to hide the source but in his videos he let slip that it was all from Tesla's experiments. In fact in one video it shows the documentation he used for the devices he presented over the years. This stuff works you just need to research Tesla's work and put it all together for yourself. I have shown a good amount of references for you guys to use in your quest to find OU. Well energy that we don't have to supply a fuel for. It is more then possible, it is fact done by the master of Electrical events, Tesla.
Read and learn then read some more and look at it from way back to see the whole picture and how one experiment led to the other. How it fits in the grand scheme of it all...
Cherryman
In my humble opinion you can also add the inventions of Otis C . Carr to this list.
Zeitmaschine
Otis T. Carr's Amusement Device, don't know if this is something real working or for amusement only. For example: »Each simulated electro-magnet 86 may be formed in horse shoe shape out of any suitable sheet material, and is provided with tubing or the like 88 around a portion thereof to simulate the winding of an electro-magnet. I further prefer to secure a plurality of plates 90 in spaced relation around the upper face of the rotating assembly 14 to simulate capacitor plates in a space craft.«
The count of the word »simulate« in that patent is rather high.
You contradicting yourself. Kapanadze also patented his device, purportedly filled with oil. But if a device of other inventors works best without oil then why bother filling up something with oil?
Back to the spark gap. A capacitor under high voltage is basically the same like a spark gap under high voltage. The difference is, the (concentric) capacitor does normally not spark, so we can draw energy from the warped Aether between its plates by appropriate means, whereas the spark gap draws energy from the warped Aether between its plates (electrodes) by self-sort-circuiting when the breakdown voltage of the surrounding air is exceeded, producing a spark that wastes the energy coming from the Aether.
Thus, a spark gap is a nice thing to play around with while doing experiments, but the real energy collector is the capacitor.
And interesting in itself, so far no one else commented here on the concentric capacitor theme. Neither thumbs-up nor thumbs-down. I would guess why ...
