GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
that_prophet
I have a diagram of this mechanism on my web page
http://free-energy.yolasite.com/
Quote from: SkyWatcher123 on January 20, 2017, 09:07:12 PM
Hi all, Hi that_prophet, the stationary bicycle generator is coming along.
Have the main structure built, need to get some parts for mounting the bike and then a long v-belt.
The bicycle has a 28" wheel, so i guess that makes the rim around 26.5 inches in diameter.
Not sure if that is a large enough diameter to see effects.
The main intention is to use it for exercise, fun and charging 12 volt batteries for powering my efficient lights.
The secondary intention, is to hook up a motor by chain, to the pedal sprockets and test out what that_prophet has been sharing with an amazing determination.
peace love light
massive
"One spark of DC electricity is all that it takes to turn a large 100cm circumference once + this gives you 100cm of moving belt. You can get an output of 1000's AC cycles, by using many=10 mini-pulleys of 1cm circumference with AC generators attached. There is no torque problem, as your AC generators are just winding up massive amounts of voltage,,, with only one spark of current "
^^^ this is the first line on your link
what is one spark of DC electricity ?
what is it measured by ?
do you know that alternators take current to energise the rotor ?
is there now a torque problem from that ?
the word Electricity comes from the word electron = CURRENT
you can only be meaning to be trying to describe simple magnet rotor passing coils .
Large alternators when left open circuit generate hi volts and the next thing that happens is they arc across the coils.....a problem.
I doubt you have done research into components or you would be able to provide detailed info , theres none on your site or on your threads ...any of your many threads on the internet.
we all know your situation , so your concept is not based on experimentation but theres nothing to stop you from reseaching the components
https://www.electronicspoint.com/
if you bothered to look on overunity you would see there are loads of threads of projects or concepts where people are trying to over come electrical problems of torque , lenz law , losses etc
that_prophet
TIME IS VERY SHORT, + WE ARE LIVING IN THE END TIMES...
Why I believe that ISRAEL'S 7 YEAR PEACE TREATY MUST START
BEFORE JAN 15, 2019 = http://2020-vision.yolasite.com/ =  1st Door
Here is a GEM of a simple free energy technology, GEM= (Geometrical Electricity Multiplication)
This was given to me by my Father, + is for the Tribulation Saints. This could be easily built, out of one large pulley,(100 cm circumference) with a DC drive motor, a belt + at least one mini-pulley,(1 cm circumference) with an AC generator attached, to be used as your multiplier. The other things that you need are, a mounting frame + materials for your AC+DC generators/motor + full wave bridge rectifiers, one for each AC generator that you attach, to convert your AC outputs back into a DC for your drive motors input. These AC+DC motors must be the same voltage, for this mechanism to work smoothly.
((( NEWS of this ancient technology will change our world )))
I have the MOST IMPORTANT NEWS =  http://free-energy.yolasite.com/ to share with you + this whole world. Unfortunately this NEWS has two sides to it, one side is the best, most awesome GEM of a God Given Gift, and the other side is the most horribly scary kind of news. THIS BEST NEWS is that FREE ENERGY is easy to produced, and can + will even lead to anti-gravity. Yes, that's right, this GEM technology will eventually lead us to a way of defeating + even repelling gravity. PROOF = this tech is found in our Holy Bible, (Ezekiel 1:16- where it is describing the appearance of a working UFO motor) = with sparks even=color of "beryl". Unfortunately, this free energy technology is meant for the Tribulation Saints, and the door closes for it to happen within the same generation that saw Jerusalem in the control of Israeli forces, on January 15, 2019
This works by only having to use one spark of DC electricity to rotate a 100 cm circumference pulley once, and then you get as an output, one to ten times 100 units of AC electricity, by connecting your AC generator to 1 cm circumference pulleys. These 1 cm mini-pulleys only need to wind up massive voltage, with practically no current, (you only need 1 spark) to rotate your large 100 cm circumference pulley.
Now Satan, and his evil followers, do not want this free energy technology to get out to the world. They use the torque argument, along with the laws of thermodynamics, to pull most people from even taking a second look at this technology. When this technology uses simple ideas, like it does not take 100 times more energy to rotate a 100 cm circumference pulley, yet you can get the 100 cm of belt to rotate 10 of the 1 cm circumference 1000 times, and if you attach AC generators to these 10 mini-pulleys, you could get 1000 cycles of AC electricity.
This FREE ENERGY technology is so simple to explain + build + use, you will wonder how it has not been discovered earlier=(evil forces were + are hiding this free energy technology). With this super simple technology, you only need to put one spark of DC electricity into this GEM= (Geometrical Electricity Multiplier) free energy mechanism, to rotate your DC motor once, and get a return of 100's or even 1000's of units/cycles of AC electricity. That is because you only need to rotate your DC drive motor once,(costing only one spark of DC current) with a 100cm circumference pulley attached. This large pulley is attached to a long belt, strap, rope, or even string,(in a pinch) strapped around your 100cm pulley + 1 to 10 mini-pulleys with only 1cm circumferences, + each mini-pulley has an AC generator attached to it + rotates 100 times, returning you 1000 cycles of AC electricity.
This GEM of a mechanism seems to defeat the laws of thermodynamics by using large differences in circumferences of pulleys to multiply your # of rotations, + using AC generators to convert the 1to10 X100 = 100 to 1000 units/cycles of AC electricity = duel sparks, into much more than the one single spark of DC electricity that you need to power your drive motor. AC electricity is converted into DC electricity by using full wave bridge rectifiers. (one for each of the AC generators)
This free energy technology is so simple in its workings, because you only having to put one spark of DC electricity in, which uses varying sized pulleys to return you 100's to 1000's of spark cycles, or units of AC electricity out. It's truly that simple, you are seemingly breaking the laws of thermodynamics, by using pulley mechanics = many small pulleys to multiply your total # of rotations, which you can easily convert into AC electricity
These AC generators run practically free of any torque, as you only need to produce one spark of DC current, (practically zero current) and torque is caused when producing power, which is P=IV, or Amps=current(I) multiplied by (V)oltage, and massive voltage times practically zero current, still equals practically zero torque. Then by using full wave bridge rectifiers, you can also easily convert your AC electricity into a lot more than the one spark of DC current, that you need to keep this GEM of a free energy mechanism running = producing a lot more than is needed to be self powering.
This technology is in the Holy Bible = in Ezekiel 1:16 where he is describing what a UFO motor looks like while it's running so this technology will eventually lead us to anti-gravity as well as not only speeds approaching the speed of light but also the ability to do 1000 kph vectoring
This mechanism works on such simple straight forward logic, that I cannot see how that it wouldn't work. Still, for all of you doubters, I have already had one person confirm that this GEM technology does indeed work, as he said that he built three different versions of this free energy technology, that do indeed work. The only problem is, that he was worried about the rumors about anyone who actually built a working free energy mechanism, soon after went missing. So, because he feared for his life, as well as the lives of his family, he asked me not to give out his name, or the fact that he had built three working versions of this GEM, free energy technology.
If you are interested in how I came to discovering how this simple GEM technology worked in the first place, as well as a few other things that He has shown me, please check out http://beliefstoliveby.yolasite.com/
BEFORE JAN 15, 2019 = http://my2020vision.yolasite.com/ =  1st Door
Of which, the second half of this duration, is known as the "Great Tribulation"
When Satan + all of the fallen angels + their offspring = (aliens + giants)
Will be sent to this earth, "woe to ,,, earth and of the sea!" (Rev 12:12)
We are allowed to "know that it is near, even at the doors" (Mat 24:33)
Because we are "this generation" that "shall not pass" = (Mat 24:34)
But in the original Greek, we are told that we must know, as in, this is worded more like a command. (Mat 24:33) "know that it is near," near to what = the door, as we are allowed to know when it's "even at the doors". These doors close on the deadlines, or when prophecy can no longer be fulfilled. Or, the day after the last day that that this prophecy can still be fulfilled, + the doors are plural, to accommodate His two arrivals = (Rapture + Glorious Appearance). Where the First Arrival is before the 7 year peace treaty begins + His Second Appearance is immediately after the peace treaty ends.
In (Mat 13:39) it says "the end of the WORLD"
Now hold on,,, our world is never going to end,
Proof= (Isaiah 45:17) + (Ephesians 3:21) = "world without end"
Where it is mistranslated + should I say "end of the AGE"
as in, the age of Christianity, (before True Christians are taken up in the clouds)
Or this WORLD SYSTEM,,,,,,,,,,,,
then using 51.6 as the
duration for the end time generation,
(calculated from 14+14+14 in Mat 1:17)
Starting with 1967.44, (when Israel took Jerusalem)
As Jerusalem was part of the 70 X 7s
MATH : 1967.44 + 51.6 = 2019.04
adding (6.9solar) = the 7 Hebrew year for the Tribulation,
then as for the door=deadline for Christ setting His feet on earth,
we would get 2025.94 = 2019.04 + 6.9
This way, we are shown both of the doors,
So 2020,(2019.04) is the DOOR,,,,,
Or should I say, one of the DOORs,
And 2026,(2025.94) is the other DOOR,
With so little time left,
As of Jan 17th of 2017,,, there is less than two years,,,
I would like to work 24/7,
But although I have been known to go 3 or 4 days,
without any down time,,,
I usually have my brain pass out,
for two to three hours, every two to three nights,,, lol
Your Bro,
. . . . . . . . joe
Just one of His Creations:
that_prophet
I mean that it only takes one spark to rotate the motor one time
the current that a DC motor takes to rotate one time
when this motor is attached to a 100 cm circumference pulley
you would get 100 cm of moving belt
which you run past 10 of the 1 cm circumference mini-pulleys,(or the size of your shaft/axle)
-   with AC generators attached to these shafts/axles
giving you 10X100=1000 cycles of AC electricity
These AC generators take no torque to rotate
-   as they only need to generate one spark of DC current
-   + torque is cause when generating power, (P=IV)
-   Or current times voltage
o   -       + since you only need to generate one spark of DC current to drive your DC motor=pracctically 0
   -       -      + massive voltage times practically zero current
        -       -       •   Still equals practically zero power = practically zero torque
(this is only to keep this mechanism self powered)
Quote from: massive on January 23, 2017, 04:20:54 PM
"thereby multiplying your AC electricity"
no multipling frequency .... to power what ?   USA runs on 50hz
" (the small pulleys do not take any torque to rotate, as they are just winding up massive voltage, as it only needs to generate one spark,(practically zero) of current)= to drive your input DC motor"
DC motors dont run on "sparks"  , is a spark an electrical quantity ?
a spark across a gap is current , practically NOT zero , have you seen commutator bars and brushes after there has been "sparks" ?
one_christian_warrior / that_prophet   ,  the devils got ya in the head and you wont wake up
that_prophet
YES,,, if you used a DC motor to drive your pedal axle, then this would be a good representation of the idea that I was given. My first Vision was a 10 speed bicycle, going uphill in tenth gear=(few rotations) + then going downhill in first gear= (paddling like crazy) = Where more rotations was equal to more AC electricity
Quote from: SkyWatcher123 on January 23, 2017, 08:55:56 PM
Hi all, i like his spirit and i am aware of the Wilson wheel and the Tilley generator.
Both of these have claimed similar effects from using either large masses or large wheels, with small generator pulleys.
I have finished the stationary bicycle generator main build, i need a long belt now.
The alternator, is a 48 volt from hydrogen appliances, i bought it many years ago and never used it, it has a built in rectifier.
Remember,  we can agree to disagree, ultimately, all that really matters, is to be kind to one another.
Here is a couple pics of project so far.
peace love light
