GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
that_prophet
http://free-energy.yolasite.com/ is a simple pulley technology, where you pay the small amount of DC electricity for one rotation of a large pulley, and then you get back the massive amount AC electricity off many rotations of a smaller mini-pulley, or maybe even many mini=pulleys. It is truly that simple,,, you are using pulley mechanics to multiply the total # of rotations, and by the simple addition of AC generators, thereby you are multiplying the total # of cycles of AC electricity. Do you see how deceptive these evil spirits have been, and doing this for so long, hiding this pre-school pulley technology. Now of course you will have to attach AC generators to each of the small mini-pulleys in order to multiply the # of cycles of AC electricity.
YOU ONLY PAY FOR ONE ROTATION OF A LARGE 100 cn CIRCUMFERENCE PULLEY
+ BY SIMPLY USING THE PULLEY TECHNOLOGY OF MANY MINI-PULLEYS
YOU CAN MULTIPLY YOUR AC ELEVTRICITY BY 1000
IF YOU USE 10 MINI-PULLEYS OF 1 cm CIRCUMFERENCE PULLEYS
WITH AC GENERATORS ATTACHED
(+ these mini-pulleys with AC generators attached take no torque to rotate, as remember you only need to generate the super small amount of power to rotate one DC motor one single time = in order to have this system self powering)
+ of course you need full wave bridge rectifiers, to convert your AC output back into the DC electricity that your drive motor needs
Low-Q
QuoteYOU CAN MULTIPLY YOUR AC ELEVTRICITY BY 1000
No, you can't. Our allmighty God did not create physics to work this way.
You, on the other hand practices the 2.nd and/or the 6.th deadly sins:
2. A lying tounge
and/or
6. A false witness that speaketh lies
So, stop trolling this forum with lies.
Vidar
that_prophet
PLEASE EXPLAIN YOUR LOGIC,,,, why will my GEM technology not work?
back your condemation up with facts + logic
please explain to me where I went wrong
in multiplying massive amounts of AC cycles, from mini-pulleys
off one small bit of DC electricity to rotate a very large pulley
Quote from: Low-Q on June 28, 2017, 07:45:41 AM
2. A lying tounge
and/or
Vidar
Low-Q
You've got explanations already, but you refuse to believe them because you for some reason believe that common well known physics doesn't apply. Have you ever done practical experiments that is based on your idea? If you do, you will be surprised how physics doesn't care about God, the bible, or any codes in it.
Quote from: that_prophet on June 28, 2017, 09:09:14 AM
citfta
This has already been explained to you several times by those of us that have actually worked with motors and generators for years.  Your biggest mistake is you keep ignoring the torque fact.  You keep insisting it doesn't matter.  IT DOES MATTER!  You cannot just ignore the torque requirement just because you don't think it matters.  IT DOES MATTER!  In order to turn even one small alternator faster than the DC motor driving it the DC motor will require much more than a small spark of electricity.  It will require a steady supply of current that will exceed the amount you can get from your alternator.  And as you add more alternators the current requirement will go up again for each alternator you add.
You are not a prophet from God.  You are being used by satan to convince non-believers that Christians are a bunch of crackpots that believe in foolishness.  I really feel sorry for you.  You obviously want to help others but instead you are only causing irritation by your constant insistence that you are correct.  You keep posting the same thing over and over again when it should be clear to you that no one on this forum believes what you believe.
I am a Christian.  I believe in the rapture.  But the Bible makes it clear that only God knows when that will be.  Even Jesus said he did not know.  I do believe we are approaching the end times but to set a time for the rapture is clearly not in agreement with what the Bible says.  You are doing a disservice to God and to your fellow Christians by making these false claims.
Please stop posting on this forum.  It should be clear to you that you are not going to get any followers here.
Respectfully,
Carroll
