GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
Paul-R
Quote from: SkyWatcher123 on March 23, 2017, 12:17:23 PM
How about one very large rotor wheel, like 3 feet in diameter or greater, with magnets around perimeter or close to edge.
This big magnet wheel could be separate mounted with dedicated bearings, then shaft coupler or chain or belt drive.
Then, one coil mounted at periphery, would act as the small pulley at alternator.
Then as many coils as one likes can be placed around wheel, next to the magnets.
I think you'll find this is described in Patrick's Chapter 2.
SkyWatcher123
Hi paul, yes i think if i recall correctly, that is the work done by lee tseung or someone else.
Though i don't think they have also implemented Thane Heinz coil methods.
So that could make things even more interesting, beyond the leverage, pulley mechanics advantage that, that_prophet is talking about.
peace love light
that_prophet
To rotate your DC motor you need massive voltage, + practically zero current, only enough current to crank over thee DC drive motor one single rotation. With this one rotation of your DC motor, you are also rotating a 100 cm circumference pulley, which gives you 100 cm of moving belt. If you run this moving belt past 10 one centimeter circumference pulleys with AC generators attached, you would end up with 10X100=1000 cycles of AC electricity.  These 1000 cycles of AC electricity are running free of practically any torque, as they are used to wind up the massive voltage that is needed to crank over you DC motor.
Torque is caused when you are generating power, and P=IV or Power is equal to "I"-current times Voltage. Since practically zero current times even massive voltage, still equals practically zero, there is practically zero power + torque being created. So, each half of this system is powered by the other half of this system, where the many cycles of the AC generators are just winding up massive voltage, which is needed to crank over your DC motor just one single time.
SkyWatcher123
Hi that_prophet, did you look at previous page, the post i made about a possible equivalent design.
Let me know if you think it fulfills the operating principal.
peace love light
that_prophet
This free energy method, (GEM=Geometrical Electricity Multiplication) is super simple, in that it uses multiple # of different sizes of pulleys to multiply the total # of rotations. Then by simply adding AC generators to these multiple # of mini-pulleys, we can actually multiply AC electricity.
Please remember, these AC generators run free of most all torque or resistance, + are like free running electric motors, with the only resistance being the viscosity of the bearing lubricant. These 10 AC generators only need to generate the minute amount of DC current to rotate this one DC motor one single time. That's practically no current divided by 1000 rotations, which is practically 0 divided by 1000. So you only need 1000th of practically nothing for current, and practically zero current times even massive amounts of voltage still equals practically zero. In being easily able to generate this miniscule amount of current, the amount to rotate a DC motor one single time. You now have the free output of a self powering set of 10 AC generators, along with the single DC motor's output.
You do not understand,,, this is sooooo...... simple,,,
This takes the 100 cm of belt that comes off the single rotation of a 100 cm circumference pulley,
+ runs this length of belt past 10 mini-pulleys of thee one centimeter circumference pulleys, which gives you 10X100=1000 rotations + by simply adding 10 AC generators, you can have 1000 cycles of AC electricity.
So although it may cost massive amounts of voltage to crank this large pulley over once, it only costs you one flash/spark/bit of current, to gain 1000 cycles of AC electricity, which can easily gain you the massive voltage that you need to crank over your DC motor one single time. And, because you only need the one little spark of current to rotate your DC motor once, these AC generators rotate with practically zero torque.
This is a self powering set of AC generators + your one DC motor, all that is missing is 10 full wave bridge rectifiers, to convert your AC output back into a DC input.
