THE RANT ROOM
Started by ramset, April 25, 2017, 04:30:05 AM
WhatIsIt
By talking to educated people outside this forum about medium of space,
who came to similar conclusion of medium existence.
And if medium is substance which is hard to compress.
Then matter becomes easily compressed.
Something like bubble of air at 10km of depth in ocean.
It can resist pressure, and take stable form and size according to pressure.
Also bubble reacts to movement of water, or waves propagating through water,
waving bubbles back and forth, shaking them,
and bubbles can influence movement of water too (if there are trillions of bubbles together).
Like mater does, trillions of atoms together.
We explained gravity so easily in that model, and other things.
And we had conundrum again.
To follow known facts and throw away everything or accept new find because it can explain gravity,
which no theory today can not. With so ease, you won't believe it.
This model reverses Einstein theory of growing mass, to shrinking mass while approaching speed of light,
which opens numerous new possibilities.
This is just one example, just one.
AlienGrey
EMJunkie
Quote from: WhatIsIt on June 28, 2020, 12:34:20 AM
You see conundrum here?
How did you get to the point when something becomes fact and provable fact?
By speculating, trying, failing, making theories (right or wrong, doesn't matter).
Just don't tell me and to the whole world that you did everything from first try!
That is why I said that you chained yourself, and you not even noticing that.
I have no Chains, I use Logic! Logic is undeniable! Period! You really need to take a page from Sherlock Holmes Play Book! Every serious Researcher should! Its important!
You speculate, its not a good method, not safe to come to any real conclusion! Facts are real, no one can be chained if they have facts! Your'e far too eager to judge, to categorise others when you have no information or facts!
Best wishes, stay safe and well in these dire times,
   Chris Sykes
WhatsIt,
cw and ccw  https://study.com/cimages/multimages/16/magnetic_field_current.png
The Barry Lebost Wind turbine ,the Lebost book "The Universal Properties of Acceleration"   https://www.barrylebost.com/upofa
Kango Iida Hydraulic converter
Andreas Sumera counterrotative gear
Edvid Linevich counterrotative gear system   https://overunity.com/15704/is-newtons-law-at-risk/
( Robert Cook Inertia propulsion engine ,centrifugal to linear
https://www.americanantigravity.com/robert-cook-jr-on-inertial-propulsion     http://www.rexresearch.com/cookip/cookip.htm
    Years ago, Albert Einstein remarked:
"When first studying mechanics, one has the impression that everything in this branch of science is simple, fundamental and settled for all time. One would hardly suspect the existence of an important clue which no one noticed for 300 years. The neglected clue is connected with one of the fundamental concepts of mechanics --- that of Mass."   )
https://www.youtube.com/watch?v=hW7DW9NIO9M           or      https://www.youtube.com/watch?v=eOCKNH0zaho
The most famous equation in all of science is Einstein's E = mc2, but it is also frequently horribly misunderstood and misused.  In this video, Fermilab's Dr. Don Lincoln explains the real truth about this equation and how people often use it wrong.
The equivalence of mass and energy, or E = mc² for short, is a natural law discovered in 1905 by Albert Einstein in the context of special relativity. [1]
In today's wording it says that the mass  m and the rest energy  E of an object are proportional to each other:
E = mc²
Where  c is the speed of light.
( But this is a "time delation"-relativity world formula   https://www.youtube.com/watch?v=yuD34tEpRFw )
A change in the internal energy of a system therefore also means a change in its mass. Due to the large constant conversion factor  c² energy conversions, as they are typical in everyday life, are accompanied by only small, hardly measurable changes in mass.
The mass of a typical car battery increases by only 40 ng due to the electrical energy stored in it.
https://translate.google.com/translate?hl=de&sl=auto&tl=en&u=http%3A%2F%2Fwww.vixri.com%2Fd%2Fgermany%2FProf.%2520Alfred%2520Evert_Windrad%2520im%2520Keller.pdf
Acceleration : doubling the speed = 8 times the force
https://www.yumpu.com/de/document/view/20184764/otto-stein-die-zukunft-der-technik-pdf
Sincerely
OCWL
p.s.: SR is not introduced by Dr.Albert Einstein but by his Professor Dr.Hermann Minkowski
       relativistic space= " Minkowski Raum" and relativistic "Lorentz force"- velocity converter
p.s.II : https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=20130314&CC=US&NR=2013062983A1&KC=A1
magnetic ring
  https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=58&ND=3&adjacent=true&locale=en_EP&FT=D&date=19910411&CC=DE&NR=3928644A1&KC=A1
generator with magnetic ring , patent offfice peers reviewed and granted !
   https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=57&ND=3&adjacent=true&locale=en_EP&FT=D&date=19900816&CC=DE&NR=3939081A1&KC=A1
WhatIsIt
Quote from: EMJunkie on June 28, 2020, 04:12:02 AM
   Chris Sykes
Sad, Mr.Sykes. With all yours superior   logic you did 1.8 Cop.
One Kapanadze has 100 times better logic than you in that case with his Cop, and is probably 100 times smarter than you.
Are you decades in front of Kapanadze too?
You love facts?
Then Kapanadze is milenium in front of you, thats a fact.
