THE RANT ROOM
Started by ramset, April 25, 2017, 04:30:05 AM
WhatIsIt
If we don't speculate and have new ideas,
we will be forever standing at same spot.
FOREVER!
You, Chris, chained yourself in so much chains,
that you stop to question yourself.
You wanna others to carry same chains,
because your knowledge is absolute and always correct.
You even do not realize that anymore because you don't care.
In your mind you collected all knowledge and stopped.
You have sharp mind, that is no issue.
On the other hand Nick is free like butterfly,
free of chains, and sharp minded as well.
That's I like him.
He accepts what he needs, and throw away garbage.
Simple.
Don't take this post as insult or try to provoke you,
try to see one grain of what I am talking here.
NickZ
   I am still learning many things, nor have I given up on my project. However, I have decided that I should not be attached to just one type of device, nor expect any fixed outcome, therefrom.  As I now have little to NO expectations as to a certain device having to bring me the outcome and success that I have been going towards. I leave the door open to any other form of self running device, being brought to my awareness, which may possibly be even much better, than what I can presently imagine.
   I do imagine what I want to build beforehand, detail by detail. But, my rational thinking mind alone, does not know how, and is not programed to let me know just how to go about building an OU device, perhaps my higher mind does. Time will tell.
    I also believe that we will know what we need to know, when we need to know it.
     NickZ
WhatIsIt
You are not alone, same here.
About your device.
It has:
1. HV coil
2. Inductor
3. Grenade
I did not build it and can not discuss much about its work.
HV coil and inductor are known.
Grenade coil has CW and CCW, right?
That is interesting part.
Something happen's with rest of circuit when you try to zero fields,
that is my best guess.
And that is what I am doing right now.
Investigating how components in circuit behave when I am using opposing field coil.
Not at way as Chris does.
I will try his approach as well (don't be insulted Chris).
I already tried, but was quick and sloppy, and failed. Does not mean it won't work when done properly.
I am using bifilar coil configured as zero inductance for my tryouts.
NickZ
   WhatIsIt:   Yes, my device has two separate circuits, that are meant to work together to heterodyne, and mix both frequencies together.
It is not a simple device, although both of the two circuits, HV circuit, (the Kacher), and induction circuit (push pull/yoke circuits), appear simple on the surface, their interaction is not simple, at all.
   Yes, the grenade output coil 37.5 meters long does use 1/2 CW and 1/2 CCW windings.
   The kacher secondary coil going to the antenna coil, also sports a reverse wound coil on ferrite rod, or bar, in my case, as well.
   NickZ
WhatIsIt
Quote from: EMJunkie on June 27, 2020, 10:45:47 PM
I agree with all you said, until I got to that bit - Far too much speculation there! I prefer to stick to provable Fact!
You see conundrum here?
How did you get to the point when something becomes fact and provable fact?
By speculating, trying, failing, making theories (right or wrong, doesn't matter).
Just don't tell me and to the whole world that you did everything from first try!
That is why I said that you chained yourself, and you not even noticing that.
