Overunity is it possible?
Started by lltfdaniel1, October 08, 2017, 01:41:49 PM
lltfdaniel1
You may have had a few laughs at me but just brain storming.
Regarding the cold electricity/power/vacuum the more i am able to see how these over unity devices work using my own brain storming methods.
Need to know all the in's and outs as to how you can get a fluctuating vacuum, that will be a big step venture into the world of free energy.
Or a build up of vacuum energy so it then starts to fluctuate?
You can indeed inject power from vaccum into a hot circuit using a special spark plug or spark gap.
I now view this vacuum energy as the driving force.
This is quantum energy so it is different because quantum physics say so with overwhelming evidence compared to standard laws i.e. you must not treat this alien force as being the same as standard electric, it not adhere with current laws you accuse me with.
This alien force/zpe/vaccum has it's own set of laws because the nature behavior of this alien force/zpe/vaccum is exactly that that isn't the same as with the conventional law you accuse me with.
It would be clear with zpe/vaccum is alot different when compared to standard conventional laws.
For zpe/vaccum conventional laws do not apply here, it has its own set of laws that isn't exactly the rule book to follow. If you treat zpe as conventional you will fail miserably.
If zpe/vaccum fluctuates then what is that called in conventional laws please because it will fluctuate the electro magnetic field giving you the impossible because the laws are different as have said!!!??? - the reason why i said this is because it is known everywhere on earth regarding the laws which say you cannot have a fluctuation from the vacuum.
I can see it would have a replenishing effect also a double mirror effect which enables the replenishing effect and the circuit gets colder as well as having the opposite effect on battery's regarding wear and tear it is opposite so the battery never wears out and so the circuit doesn't cut this force off.what I am on about is the paragraph above this paragraph about testing the fluctuating force from the alien vacuum energy, yep done in a conventional law circuit this also saying they don't teach this in school and the energy goes to infinity so it definitely is zpe/vacuum energy, i would use an open circuit and use the earth because it needs a unbalanced electron spin for it to work or other ideas surrounding this.
Since i said about the fluctuating force from the vacuum effecting conventional electric physics they added a paragraph explaining this effect and yes has no limit as it goes to infinity
I can see a motor making use of the fluctuation effect/replenishing powering up with real power/torque from the vacuum.
The circuit was up against the power from the vacuum, so the fluctuating effect was present in the circuit and it really could not operate but was running because energy was being cut off and it was causing stress in the circuit so had to be off loaded and understood there was a double mirror effect of the mirror effect one side depletes(hot circuit current like with mostly every circuit on the planet) and the other replenishes ( cools and is totally opposite to the hot current) and was detected in the circuit and understood why it was under stress.
The instrument that you use to measure volts and amps with the circuit in replenishing mode was entirely negative/negative voltage causing the circuit to get colder and colder not hot.
I wonder if you can get the fluctuations to self power it self actually yes fully is possible that will be your unbalanced spin drive in stead off the unbalanced spin in the earth where the fluctuations give you a unbalanced spin so use the fluctuations spin and vollia.
If you wanna try you have to have something that achieves speed of light to fluctuate the vacuum doing the earth circuit and it will run just look at my previous post, what you end up with it is a rpm at a constant pace with true vacuum power running it whilst it is in harmony with the earth and there you go and you can get power from it as well.
I think someone tested this and it violently shook with real momentum.
Now i can see it is now self-sustaining perpetually running with power.
I can see a machine running as well off vaccum energy using this method which is my  point of view > If zpe/vaccum fluctuates then what is that called in conventional laws please because it will fluctuate the electro magnetic field giving you the impossible because the laws are different as have said!!!???[/size] [/size]
So how does it work well flucations from the vaccum and the unbalanced spins of zero point, which causes magnetism and the like to have unbalanced electron spins one bigger than other like scaler waves that is how it all works.
It makes sense the spins of zero point pop out of nowhere just like atoms that show up and then dissapear it is exactly like that.
With the fluctuation atoms from another realm comes and pops into our realm
with a vibrating zero point fluctuation or fluctuating rapidly the atomic structure now has subatomic particles to achieve this, the sub atomic partical is where the power is so the sub atomic partical enters into our realm.
so the more you vibrate it the more energy you get as in capturing particals it captures the partical by it self and when u vibrate it creates power, so it is like a invisible device where you shake to get power and with a self powering vibration so you dont have to like the zpe flucation
so with vacuum fluctuation the process is this it sucks in subatomic particles into our realm and gives us power simply put and the  physics of this is a unbalanced spin one bigger then the other that is where the magic is.
laws of the realm eh well when the particle isnt in our realm it gives nothing exactly that but when it is , it gives power it automatically comes to the realm where the source of attraction is, it is like a natural harvesting bucket.
So with the quantum fluctuation, the nature of this energy is one tiny spin and one big spin which says alot so it is already self-powered and if you did this with gravity then it will tapp into vacuum energy, i wonder what the quantum/zpe/vaccum fluctuation/vibration is like with the gravity wheel.
So it starts off as self powered and the pendulum of gravity will mimic the zpe energy fluctuation translate that into a gravity wheel and you have a perpetual vaccum energy gravity wheel with one big spin and one little spin and these spins will come into our realm so you have them or with magnets.
i can see the quantum scalar effect self running  in unbalanced vaccum spin method and have a real power torque to it so it self run and being able to power a load.
at an angle so you be able to control the speed of the device running of vaccum unbalanced spins borrowed from some other realm.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
lltfdaniel1
Every time you wack the vaccum field you automatically get energy from the vacuum.
Regarding vacuum fluctuation so a spark plug can do this or in gravity with a wack or any other Wacking method.
These parts have to been designed to tap the fluctuate field so you can vibrate it to give you power simply put.
lltfdaniel1
Taking advantage of Zpe spins, it has to be self vibrated regards the Zpe fluctuate field so these spins take affect in our realm and thus through electro magnetism you have unbalanced electron spins to use. Zpe spins are unbalanced and is perpetual.
I cannot find a picture showing you the zpe spins.
The ancients knew of this. They said Godhead periodically created new Universes by breathing out, and de-creating other Universes by breathing in. These epochs were called Yugas. Modern science called this the Big Bang [/size](theory)[/size]. I was in absolute, pure consciousness. I could see or perceive all the Big Bangs or Yugas creating and de-creating themselves. Instantly I entered into them all simultaneously. I saw that each and every little piece of creation has the power to create. It is very difficult to try to explain this. I am still speechless about this.[/size]It took me years after I returned to assimilate any words at all for the Void experience. I can tell you this now; the Void is less than nothing, yet more than everything that is! The Void is Absolute Consciousness; much more than even Universal Intelligence.
From [/size]https://100777.com/spiritual/beings_having_a_physical_experience
I can tell you this now; the Void is less than nothing, yet more than everything that is! - this is the energy from vaccum/zpe spin it is unbalanced by nature.
Those unbalanced spins justify power to create and destory, if this wasn't the case then where did the universe come from if cannot create nor destory eh?
You wouldn't be able to have a universe if that was the case don't you think that is obvious enough? - the answer is this > I saw that each and every little piece of creation has the power to create. It is very difficult to try to explain this. I am still speechless about this.
If energy from the vacuum was balanced then what causes it to shoot of to infinity and cannot measure it.
If it shoots off to infinity then it has the power to create energy done by the potential energy of going off to infinity.
Some thing about motive force I think if it wasn't the case as in having real power to self run perpetual motion then it would be impossible to go off to infinity if you think about it.
lltfdaniel1
So where do all these motive forces spawn from the forces are imbalance and the motive forces.are different like zero point where its motive force goes off to infinity.
I'd tap the motive potential of zero point and have it in electric field so an electronic circuit goes off to infinity.
As in acceleration getting harder and harder So by it self it will get faster and faster while self running this is same principle where it goes off to infinity.
The way it goes off to infinity already breaks the laws of physics because it self runs with created power.
If you study why all the process of why it shoot off to infinity then you get the unbalanced spin you will have a true self runner giving power I am confident about that.
There is indeed suppressed science papers that support me.
I can see people have succeeded with this, it really is a different energy regarding zero point they now have devices breaking laws of physics.
lltfdaniel1
Actually yes you can indeed get a heat pump to be like a self runner but isn't because it cuts off the source. I can see the circuit and would work in that fashion because externally it extracts power and overcome the limitation and use this limitation to extract more heat using the heat from the external factor.
I can see it definitely would work exactly like a self attracting solar panel effect where it encourages the external energy extraction to overcome this because my previous idea didn't work regarding earth circuit and a self running heat pump so I have the right concessions.
In principle in science you can externally extract energy to overcome limitation to extract power and then close the loop so a self running solar panel and isn't perpetual motion.
This is also called em drive where you run off extracted energy to power the extraction process with power to spare and power a load.
You will be limited as to how much you can extract but there will be no limit as to how much you extract thereticly speaking.
I am now in the realm of understanding.
If you do this with the earth it will now work and same with heat pump after all my post, this post have nailed it so it does work this time around.
