Overunity is it possible?
Started by lltfdaniel1, October 08, 2017, 01:41:49 PM
lltfdaniel1
I wonder what other devices that can cause the vacuum to fluctuate wildly so you directly extract power from it.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
lltfdaniel1
I had an idea you can cause the vacuum to fluctuate wildly.with little power from said device. Then it would take off with power torque.
Need to know more from quantum mechanics.
So from quantum mechanics I know that when the vacuum fluctuates your now have succeeded in energy extraction holy grail it is like fluctuateing the electro magnetic field and electron spins.
lltfdaniel1
So you need to have a electric circuit design taking advantage of the quantum vacuum fluctuation and use that to encourage the vacuum to ever more to fluctuate wildly whilst being at the threshold it will cause the magnetic field to fluctuate giving you real power torque so this is the main key.
It really would work like that with the fluctuations even in quantum mechanics it is clear.
I wonder how to get the threshold with little power as you extract power and then use the power to power the extraction process with power to spare the main thing to get it to work like that is via quantum vacuum fluctuations fluctuating wildly so it will work fully and will be of cold not hot in the electric circuit because the em field will fluctuate as well.
My idea is using the earths own cold electric circuit/vacuum using the earths own vacuum and fluctuating the earths own vacuum energy so that will fluctuate which means it will fluctuate in your circuit.
There must be methods to deal with the fluctuation process which is what i need as well. This is like perpetual motion but isn't. The extraction of energy is unlocked with a fluctuating quantum field causing the em field to be like that and in that force of the fluctuating bears real power torque and is different kind of energy all by it's self when compared to extracting energy and using the excess energy for a load regarding using extracted energy to power the extraction process with power left  over for a load that is but the fluctuation of the vacuum is the final key to get it to work like this.
The threshold is where the circuit implodes in your face, so in essence the circuit has to speed up to tap energy from the vacuum as it is called.
What would happen is i now have got my earth circuit device to work, and all it needs is energy from the vacuum process for it to be unlocked to work.
There must be ways to cause the vacuum to get excited ie wild fluctuation so you have a real driving force and to extract it with taping methods, instead of water hammer and the like do those kinds of effects with the vacuum it self prehaps, if you did water hammer of cavitys the best you would get is a under cop 1 circuit but has extracted energy in it whereas the vacuum with its wild flucation gives you cop above 1 by nature.
In physics you now have a true over unity motor thanks to the vacuum and it's wild flu cation and the wild fluctuation is where it all begins.
It isn't breaking the energy conversion law either.
It well and truely is extracting energy from the vacuum not some over unity magnet induction motor (you cannot extract energy from environment) this what i am on about is the real deal regarding my physics standpoint (extracted energy from environment via the earth with its unbalanced electron spin and vacuum fluctuation) and is proven to work as i stated.
If it was not for the unbalanced electron spin my methods in all my post would not work any case it does work plus vacuum fluctuation
When you have energy from vacuum fluctuating wildly the motor will have a constant rpm with torque/power/work done via the earth.
I wonder the nature of the energy regarding the vaccum and how it equates with lenz law and the like to over come the bottleneck in the circuit so it doesn't implode  in your face, when i mean implode  in your face i am on about my other posts regarding imploding in your face anyways with this just finding out how to bypass the problem which lets you hit the threshold to tap energy from vacuum fluctuations.
This vacuum energy is a different kettle of fish, it behaves different when compared to lenz law, explain that in quantum physics and people will buy it.
Since the energy is different is behaves not like usual physics the physics are certainly different with the vacuum/zero point/etc this force is alien in that retrospect.
Now i am having to have to explain that in layman's terms.
Thing's like bending space time using quantum mechanics.
Bending space time can/could be used to give you energy as well.
You can manipulate the energy field to extract power using the bending of space time to also knock on the door.
But it costs energy so yea like with the particle accelerator antenna.
Needs to be transition into a cold circuit not hot.
lltfdaniel1
Like a warp drive like star trek the faster you go until you break the threshold to cause the vacuum to fluctuate with the surrounding vaccum communication with the bended field to extract power as well.
Since the space drive is going through space it could use the vaccum it self for propulsion and going at the speed of light which is where it causes the vaccum to fluctuate, you see where I am going with this?
Like folding space but it is swimming in a sea of energy which is the vaccum/zpe.
It is like an invisible circuit which is what it is.
Yep am correct > http://techland.time.com/2012/09/19/nasa-actually-working-on-faster-than-light-warp-drive/ proves the principle
The threshold is the speed of light in a circuit know any method to achieve that so I can get a fluctuate vaccum without an implosion in my face..
lltfdaniel1
So yeah I now know that I need components that do the speed of light...which I can see would exist I mean the particle accelerator only goes near light speed and not light speed it self so that wouldn't work.
