Overunity is it possible?
Started by lltfdaniel1, October 08, 2017, 01:41:49 PM
lltfdaniel1
Maybe a quadropal transformer to separate the forces?
I need to separate the forces to accomplish this as a.alternative.
Like bus lanes but it will  return energy back to earth and need s to be modified and can see that it most certainly will work.
It taps faster and faster thanks to the particle accelerator antenna.
With inter exchangeing the energy so energy can communicate with each other so the process works.
And have it where it taps into energy automatically with the interchange of energy and the interexchange can automatically tap into the energy.
The bus lanes will be transformers and with this method I can see it will bypass lens law
The exchange method can in actual fact do that regarding automatically tapping the energy.
With the I terexchange of energy and communication you can in fact manipulate the energy field to work towards your advantage with this method.
The natural dis burst of the atom is the same as tapping into energy you know like switching to capture the energy. And to manipulate the field to give you more of that.
so the natural dis burst of the atom is accelerated thanks to the particle accelerator antenna and the whole thing has potential to take off with real power/torque and it will need some tuning as the dis burst of the atom will be very slow due to the earths resonance of 7.8hz.
The dis burst of atom is exactly that regarding tapping with switching to capture the energy but this is different but same effect.
You know circuits that tapp into the energy regarding bypassing lenz law in a circuit like an avalanche and have called them jolts of power/torque in previous post so yea it doesn't take off because of lenz law.
So now you are extracting energy with no limit it wont be enough to self run using the extracted energy to power the extraction process but clearly see a threshold where it most certainly will.
The threshold is where all the magic happens a self runner thanks to running off extracted energy and energy to spare just have to make sure it wont implode in your face, this implode is why it will make the circuit go colder and colder.
your going to have to make a circuit where it doesn't implode in your face and work at same time.
I'd study why it gets colder and colder regarding the circuit and thinking out side of the box as to why and if you know why all your circuits will be getting colder and colder and have successfully mastered the art of energy extraction so it self runs with power to spare which is all done solely by extracted energy with power to spare for a load so it works like a solar panel.
In physics this is exactly what will happen and is the holy grail it self, i'd look at how the earth has it's own coldness within its own earthen circuit to start with.
I don't know how to over come limitations with the circuit and thresholds so it doesn't implode in your face but someone with a working brain will know what to do., it would be translated into a circuit and work and isn't perpetual motion but the force is like that just running solely off extracted energy with power to spare for a load so this is indeed is unbalanced.
i need to know how to make the circuit compatible because it runs hot which is one opposite and the other is cold so it runs in harmony when it switches from hot to cold.
So if you want a motor running off extracted energy powering the extracted energy with extracted energy with power to spare for a load i am afraid to say the circuit has to be cold getting colder for the extraction process to be complete.
So if you don't know how to get the colder and colder in a circuit, just copy and emulate the earths own colder and colder circuit which definitely is present in the earth.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
lltfdaniel1
Anyways i have no doubt that someone would have succeeding having over unity purely from extracted energy whilst being powered by that extracted energy with power to spare for a load.
So yea would be able to modify all my ideas so you reader can extract power.
So yeah a simple circuit with partical accelerator antenna of both ends i think, anyways getting power from the earth is already proven just use that power from the earth to get even more power until you have a cop above 1 using the partical accelerator and powering it with the extracted energy it will accelerate the amount of extraction power you have got as well as accelerating its distance to capture ions as well so it will be in the ionosphere where there is a dense amount of ions to extract from.
I didn't know what it was called but wanted it and yep the partical accelerator antenna will allow you to tap right in the ionosphere with ease.
I am using theatrical physics to prove my point.
A Static powered particle accelerator antenna would be lovely, then convert the static electric into dc electric.
Looking at this https://peswiki.com/directory:atmospheric-electrostatic-energy we can indeed convert static power into usable power, i wonder if all the inventors ever thought about using a static powered partical accelerator antenna, would love to ask them and recommend it to them all.
The particle accelerator is the only thing that i know of that excites the process of energy extraction, like a runaway train going down hill faster and faster whilst being self-powered, it would easily achieve over unity.
lltfdaniel1
http://www.ph.surrey.ac.uk/partphys/chapter4/ElectroAcc.html
Something like it but isn't a static powered particle accelerator antenna.
The static powered particle accelerator excites the extraction process with a train always going down hill by tapping into the earths ionosphere.
I want someone who reads this to make a static powered particle accelerator too taps the ionosphere of the earth!
That way you get a ton of electrostatic power.
In my theory about the static powered particle accelerator beam gets longer and to somehow use this particle beam to suck in electrons/static/ions/whatever.[/size]
I think in physics you can indeed suck in energy doing it via this method.
https://en.wikipedia.org/wiki/RF_antenna_ion_source
to extract via the beam is by putting something in the beam it self i think something that acts as a mirror like a magnifying lens.
Every time the particle accelerator slams into something it gives energy or it takes energy so yeah.
So when it captures energy this way you relay it to power the accelerator it self.
lltfdaniel1
The antenna needs to be small enough because you will get some milliamp of power from static so the antenna functions.
lltfdaniel1
Because the earth's RF has very long waves of Hertz it will take time for the antenna to catch up to use the earth's power to its fullest regarding real power torque.
The antenna has to be positive only using one wire connection and through one wire is all the positive static with no negative.
And on other end single wire negative only from the ground.
Like a spark gap but consistent regarding the antenna extraction which I think would be ideal because that effect causes it to harvest energy or potentially regarding different energy's that we are not tapping.
Regarding dissipation it could spark or ignite the process
It would cause it to swing like a pendulum with momentum as well as causing vibrations and these vibrations by them selfs are unbalanced so it would have real power/torque there as well which is banging on energy extraction door saying let me in i am of the cold variant not hot. Simply using the earth's unbalanced electron spin translated into the pendulum swing via gravity and extracting energy via gravity as well.
so if you know how to cause these vibrations and how to tap them like a spark gap then you stand a much better chance.
So if you cause vibrations with the earth circuit then it would work.
Not sure about anything else because it the earth circuit needs that unbalanced electron spin to vibrate like that unless i am mistaken.
All of these phenomenon and problems are really ladders to  energy extraction which can never work in a hot circuit, only cold because it is evident that it is implosion not explosion that is if you want it to self run done by energy extracted to power it self and a load.
Like cavity's, cashmir effect etc. Water hammer maybe electric discharge.these effects have real momentum of power and torque as well as fissures.
http://physicsworld.com/cws/article/news/2012/jul/18/physicists-solve-casimir-conundrum
