Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
0 Members and 102 Guests are viewing this topic.
ramset
Stefan if your friends won't share their work here [seems none of Ricks students will either ...]maybe put a budget to this and we'll pick a builder to fund .
and do it here .100% transparent energy audit .even let Rick pick the builder !!
end of story..
EDIT HHmm  here member Tito dropped off a related PDF he says keeps getting removed ?http://www.borderlands.de/Links/Free_Energy_Multiplier.pdf
Tito is another member professing Christian values ...by keeping secrets ...[is it ten years now ??]
I never heard this about Christianity until I read Tito ...and now it seems contagious ...a new face here.
No lives matter .. when everything is good at Tito's house and....  the lives who can Pay ?? ...at ...
somebody plays God here ...but its definitely not member Poynt
Thanks Grandma
Void
Guys, regarding statements about a circuit setup which can supposedly improve efficiency when powering
12V fans or 12V light bulbs, if you power 12V light bulbs or 12V fans from a 12V battery directly
with no circuitry in between, then you are powering those loads with essentially 100% efficiency.
(Regarding fans, assuming the electric motor in the fan already has suitable power factor correction in place.)
The only way an intervening magic circuit X can improve on 100% efficiency is if your magic circuit X
produces a COP > 1. There is no other way to improve on a setup which is already essentially 100% efficient.
See the attached graphic for illustration of what I am saying. :)
If some given magic circuit X is really COP > 1 of any significance, then you should be able to self loop the setup so it self sustains.
All the excuses and deflections in the world won't change these plain and straight forward facts.
WhatIsIt
Until this morning I did not know that Mr. Gear is R&D Simens. His deparment has 136 employes.
They already this Rick motor test with AC source in the past.
I will not go into details of reactive power, which in Ricks case splits, returning power to battery and motor.
Reactive power returned to motor will increase RPM which results with more output to load which has to be capacitive or inductive. More power to load creates more reactive power and loop is created. It can go to some point.
Sorry, but no OU.
It is better than simple transformer feedback loop but still no OU.
It is replica of big systems of power companies where they use expensive motor/generators for compensation of reactive power and returning power back to grid. More complicated because their generators are AC and phase align is needed for power to be returned to grid.
Rick uses DC battery and simple rectification does do job.
When he saw Ricks video, he laughs and he pointed some things and has banned for that.
He still laughs.
So it is not new thing, power companies use it for a long time.
Rick has to have caps on load to make reactive power.
He said he wish the best to Rick and he has more serious projects to do.
a.king21
Quote from: WhatIsIt on July 30, 2019, 10:07:46 AM
Sorry, but no OU.
He still laughs.
I have just read all of Gear's posts.  Telling Rick off in swear words is not the dignity I  would expect from the head of Siemens R and D.
He should be fired if that is his attitude.
WhatIsIt
At the consumer side.
We all know if we do power correction of motor with capacitor it must have exact value to do that.
If it is too small motor will consume too much.
If it is to big, it will create to much reactive power. Thats the trick.
