Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
0 Members and 35 Guests are viewing this topic.
By companies like Siemens( spanish:Ximenez) also "Abteilungsleiter" can become fired or get with 55 years their"golden handshake' ( Fruehrente ::) ).
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.deutsches-museum.de%2Fsammlungen%2Fmeisterwerke%2Fmeisterwerke-iii%2Fdynamomaschine%2F
The dynamo-principle ( Siemens also a Physics-unit)
WhatIsIt
Quote from: lancaIV on July 30, 2019, 11:14:45 AM
http://www.patent-de.com/19860717/DE3501076A1.html
What does "Mr.gear" think about it ?
Mr. Gear was moderated because he has means and men power to quickly check all of the claims which is not good for attendance of forum and number of clicks.
While moderated he can not answer to you. He has no access to this forum and he does not think of opening another account. This tale is over for him. Thats what he said.
I liked him. He has sharpness like Mr. Tinsel and knowledge, and probably gear and tech I never saw in my life.
I am still in contact, but I am little fish for him.
He only replied because I contacted him first when I saw potential in that man.
Thats it.
WhatIsIt
What I learned from Mr. Gear mails is:
From 30 years of R&D experience, only transient math scope power measurements are valid.
Everything else leads to some kind of error, and missbeliveve of OU.
Most of the time people does not care for phase angle which can bring power down to zero while has great amplitude of voltage.
Only people which repeat that here are Mr. Void and Mr.Itsu and nobody listen.
You can not measure power with V meter and A meter. Only in smooth DC, but everything else, oscillations or square wave or you name it is transient in nature and complex to measure.
I will thank the man who teached me this. He knows to whom I refer. Great man!
Thank you!
WhatIsIt
Quote from: forest on July 30, 2019, 10:40:45 AM
I think the problem here is that nobody show the path to convert high Q into high reactive power and then this reactive power to real output power, basically converting the Q into real gain. also nobody explained how this could be possible. I've found two  reasons
Reactive power is reflected power from load to source. Overloading the source.
Reactive power is produced from inductive and capacitive load.
By putting to much capacitance parallel to motor you will create more reactive power which goes back to source. That is only one example how to create reactive power.
Try to put in series capacitor and inductor in AC circuit. They must have certain values to resonate.
You will see how much reactive power you can produce.
Your source will explode if not managed with power correction systems.
It is not hard to produce reactive power. It is hard to manage it and feed back to system without any damage.
WhatIsIt
All of this you have on youtube.
Search for reactive power and power correction systems.
Very simple stuff.
Also phase angle related to power.
You can have phase angle and no power or phase of voltage and current aligned for max power.
Thats the stuff fot begginers.
And there is no other way to calculate this without scope, voltage and current probe.
Average power math. The only way. Just as Mr. Void repeat to you always.
Everything else is fairytale.
